586,068 active members*
3,775 visitors online*
    Aug 2010
    188
    jerky tool paths
    hi all, im experiencing jerky tool paths, it looks like the machine is coming to a dead stop at each transition between G01, G02, G03, ect. how do i make the machine contour smoothly? or is it even a machine issue?
    MA550V with OSP200M
    Feb 2011
    353
    Re: jerky tool paths
    you could try hi cut pro either thru program or in the parameters
    here is where if you are using mastercam/esprit of other software
    limit the number of points that have to be read by changing the cam program to out put less code
    most controls are limited to a certain number of blocks that can be read ahead
    try to make longer moves to allow the machine to keep going
    G130 TURNS IT ON IN THE PROGRAM
    G131 TURNS IT OFF
    G130FxxxxExxxxJ2
    F(UPPER FEED RATE)
    E(MACHINING TOLERANCE)
    J(1= STANDARD, 2=HIGH SPEED)
    This may smooth out the acceleration/ deceleration going from point to point
    Jun 2015
    4154
    hy jay dizzle, if you wish, pls try to find a toolpath made of 3-4-few entitites, that behaves slowly, and share the code
    from another point of view, you could calculate the lenght of the toolpath and the required cutting time, considerind feed = constant; use this as a base line; from here :
    ... scale ( up / down ) the toolpaths
    ... change the feed rate ( up / down )
    if all ok, a toolpath scaled 2 times, with a feed decreased 2 times should perform 4 times slower; idea is to find the " scale and/or feed value " where linearity is lost ( for example, if scale is too little, or feed is too high, linearity is lost ); when that point is found, pls share the code / kindly
    ps : using the hi-cut pro should be ok as long as linearity is there, but even so, using this function does not guarantee a better overall cycle time / depends
    ps2 : there are a few parameters and special functions that can smooth out movement, but i would check that code is as smooth as possible before activating those; for example, if you activate a motion controll function and you reduce cycle time, you may get an overall time slower then a simple g-code that is smoothed
    ps3 : ultimate special function to boost hi-resolution segmented code is the hyper-surface : check this out : https://www.cnczone.com/forums/okuma...novations.html
  1. Replies: 4
    Last Post: 02-25-2019, 11:53 PM
  2. Not able to see tool paths
    By SwampDonkey in forum CamBam
    Last Post: 10-07-2014, 06:47 PM
  3. How to delete tool paths?
    By NorthridgeFab in forum SheetCam
    Last Post: 01-20-2012, 04:56 PM
  4. 3d tool paths
    By ginamc in forum OneCNC
    Last Post: 03-19-2005, 06:17 PM
  5. Tool Paths
    By WOODKNACK in forum G-Code Programing
    Last Post: 04-27-2003, 02:09 AM
