586,700 active members*
3,202 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA LB15 SPINDLE DRIVE BREAK TIME
Results 1 to 8 of 8
    Hi!
    I have OKUMA LB15, serial number 6350, build in December 1988.
    OSP5000-LG, FANUC spindle drive.
    How can I change the break time?
    The problem spindle stops very low and I need to decrease the breaking time.
    Regards,
    Photo are in attachment.
    Attached Thumbnails Attached Thumbnails IMG_7310.jpg   IMG_7311.jpg   IMG_7312.jpg
    Apr 2009
    1262
    Re: OKUMA LB15 SPINDLE DRIVE BREAK TIME
    Can you give more specific times for braking? For example from 2000rpm to stop, from 3000 rpm to stop?
    I’m guessing on a drive that old that your unit’s regenerative braking may be getting tired and may need new thyristors.
    Also what voltage are you running at and what size cable? Small cable with low voltage may affect it as well.
    Best regards
    Experience is what you get just after you needed it.
    I did video:
    https://www.youtube.com/watch?v=Vr9p...ature=youtu.be
    You can see, after the driver finished its speed decrease (break), this spindle turn several times befor stop.
    I need to exclude 1-2 rounds per second after the spindle stop.
    Spindle Drive FANUC A06B-6055-H208
    Feb 2009
    6028
    Your problem in not a parameter or drive unit. Your belts are loose.
    Quote Originally Posted by underthetire View Post
    Agree, seems it is the reason.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Apr 2009
    1262
    I agree the belts should be tightened. Try doing an M19 and see if you can move the chuck by hand due to loose belts.
    Ramp up down seems normal. Coasting after stop does not.
    Best regards,
    Feb 2009
    6028
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    No m19 on an old LB15
    I've seen this many many times
  1. Okuma LB15 201 Drive Alarm
    By RLMTS in forum Okuma
    Last Post: 06-07-2022, 03:34 AM
  2. okuma lb15 floppy drive
    By petextr in forum Laser Control Software
    Last Post: 01-26-2022, 03:21 PM
  3. Replies: 0
    Last Post: 09-01-2015, 01:54 PM
  4. okuma lb15 spindle drive unit
    By TTT in forum Okuma
    Last Post: 02-03-2011, 03:49 PM
  5. okuma LB15 spindle drive unit
    Last Post: 03-17-2008, 12:51 PM
