586,052 active members*
4,026 visitors online*
    May 2019
    6
    Where to connect touch plate
    Trying to figure out what PIN number to use for a touch plate from amazon, it may be over my head but I believe for an ess bob the parallel port is emulated by the ess plug-in. I have not opened the case containing the bob and drivers , wanted to try the easiest thing first so I connected the two wires to an input available from the exterior I have no idea what PIN number is being used but when I touch the alligator clip to the touch plate m3 home lights up on the diagnostic page and goes off when disconnected so I’m sure that is the input I wired to. The question is can I use this as is ? If so what PIN number do I tell Mach3 to look at for the auto z probe input.
    May 2019
    6
    Re: Where to connect touch plate
    Info ;the machine is a 2014 model Velox CNC vr-5050 . It uses Geckodrivers ,from the xml backup file I found ess_v10r2d1d . I looked everywhere for a spec on the ess only thing I could find on the internet was a picture of an older machines controller opened up and pontec was the maker , could not find any documentation with the information I have.
    May 2019
    6
    probably not helpful but it’s all I have with me
  1. how to connect a touch plate to auto-zero z-axis
    By Ivano in forum Australia, New Zealand Club House
    Last Post: 06-18-2017, 10:15 AM
  2. z touch off plate
    By Alwaysintheknow in forum Chinese Machines
    Last Post: 06-10-2013, 03:20 AM
  3. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  4. How do I connect a touch probe?
    By jaru-eri in forum Gecko Drives
    Last Post: 01-20-2013, 07:40 PM
