Does anyone know when backlash compensation is used by the G code interpreter?
My problem was when adjusting backlash settings in my init program I could see the changes when jogging the respective axis.
But when I ran test cuts in g code it had no affect even setting to a big value it had no effect when run threw the interpreter
I'am cutting a square and a circle
Using cutter comp
Only after restarting my computer
It would change the backlash amount and rate in Gcode
In case someone else is having this problem restarting the PC fixed it for me
