586,072 active members*
4,681 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Just another extrusion/Aluminium CNC
Results 1 to 17 of 17
    Mar 2018
    70
    Hi. I'm working on this build for about 2 years now and jsut wanted to share some pictures of the progress.
    The Framesize is 1000mm x 800mm. It is a direct driven dual drive gantry design inspired by the famous Gabriels build.
    It uses 25mm linear rails on all Axis and 1605 ballscrews on X & Z and 2005 on Y. I wanted 10mm pitch at first but ordered 5mm pitch... and for now can live with it.
    Motors are high torque Nema23 steppers. In the future I update to 400W Servos.
    Everything was done with simple tools like a drill stand and a sliding mite saw.
    This is how it will look at the end:
    Mar 2018
    70
    Re: Just another extrusion/Aluminium CNC
    This it how it looks at the moment:
    Aug 2009
    1573
    now what .leaders need a dogx2
    15362
    Quote Originally Posted by millhouse_ View Post
    5mm pitch Ballscrews are good for Zaxes but not X and Y you want at least 10mm Pitch for X and Y Axes
    Mactec54
    Mar 2018
    70
    I wanted 10mm pitch but ordered 5mm. **** happens but I can live with it.
    15362
    If you do use the servos it won't be to bad for speed, but the steppers would be very slow
    Mactec54
    May 2005
    3920
    Or how it looks as rendered.
    Mar 2018
    70
    I received the large Profiles yesterday and mounted them. Next step is aligning and squaring everything which feels like it will be much butthurt.
    Dec 2014
    640
    Very Cool!
    Mar 2018
    70
    @fretman_2 thanks. I'm very happy with it too.
    PS: Some pictures of the aligning process will follow these days.
    Mar 2018
    70
    Today I started aligning some parts.
    The left Y Profile was clamped in position with 1-2-3 blocks and attached to the bottomframe.
    To flush both Y profiles I clamped them between the motormounts.
    To get a little pressure from above I improved a bit:
    With everything clamped that way I tightend the Anglebrackets of the secondary Y Profile.
    Next step was aligning the Linearrail of the left Y Axis which was pretty simple. Just mounted a dial gage to the slide and drove along the screws. A little pressure here, some more pressure there to get it near zero.
    Last step was inserting the fastener caps. After inserting them I used a razorblade plane to cut away the overhang.
    Jun 2018
    9
    What kind of couplings are you using for the nema 24's and the threaded rods?
    Mar 2018
    70
    Quote Originally Posted by umfan110 View Post
    Simple 30mm diameter jaw couplings.
    https://www.cnc-discount.com/wellenkupplungen/122
    Mar 2018
    70
    The Y Axis is aligned. The Ballscrew for the X Axis arrived today.
    To make things more rigid I mounted a 120x80 Profile to the back.
    Mar 2018
    70
    Aligned the X Axis:
    X left:
    X center (after tightening the slave rail it changed to 0.03mm which is still fine for me):
    X right:
    Mar 2018
    70
    Just a small update. It is almost done.
    Mar 2018
    70
    Hi. Today I recognized that the stepper drivers were not connected to the +5V Terminal. Only the step- and dir- was connected to the board. But step+ and dir+ were not connected to anything. The stepper worked.
    Could someone explain why it worked?
    The drivers are DQ542MA, wired active low, but I forgot to connect the +5V.
  1. Another aluminium extrusion router
    By qwertysimo in forum CNC Wood Router Project Log
    Last Post: 01-15-2017, 04:09 PM
  2. LOOKING FOR ALUMINIUM EXTRUSION
    By dalwinder in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 08-07-2014, 02:29 PM
  3. Aluminium Extrusion to choice?
    By samsagaz in forum DIY CNC Router Table Machines
    Last Post: 10-31-2009, 11:59 PM
  4. aluminium extrusion system
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 11-05-2007, 05:37 AM
