586,103 active members*
3,298 visitors online*
Results 1 to 7 of 7
    Apr 2007
    19
    Exclamation Stepper Question
    I am looking in to building the cnc router that www.bigbearcnc.com offers. He suggest using a stepper kit from www.zylotex.com. The steppers that they have are 269 oz. in. steppers w/ a free upgrade to 425 oz. in. steppers.
    Ok, my question is, what would be the advantage to the upgrade?
    I am new to all this and this may be a stupid question, but a question that I need to ask.
    Thank you in advance.
    Brian
    Brian
    Dec 2004
    1316
    The advantage is that the motors are stronger, so they are less likely to experience a loss of steps due to strain on the motor.
    Jason
    Apr 2007
    19
    So what you are saying is that I could take larger cuts without a problem?
    Brian
    Dec 2004
    1316
    Yes it will be able to take larger cuts but the bigger the cut you take then other factors become more involved such as the flex in the machine.
    Jason
    Apr 2007
    19
    oic thank you for your replys
    Brian
    One thing to be aware of is that the larger motors may spin much slower. They'll have more power at slower speeds, but may actually have less power at higher speeds. Usually, when using the larger motors, you'll want to use leadscrews with fewer threads per inch. This will give you higher speeds and keep the motor spinning slower where it has more torque
    Oct 2006
    23
    I too was thinking about getting there upgraded system. Im not to sure if they are a good company to get that stuff from. I hear about Gecko Drives, buts its even more confusing.....
    Im working on a RockCliff design, working on making it with much less flex
    This site changed my life ----> www.alittlebiteasier.net
  1. Stepper Question
    By ignatz in forum Stepper Motors / Drives
    Last Post: 04-23-2005, 10:26 AM
  2. 180 oz Stepper Question?
    By jdebuck in forum DIY CNC Router Table Machines
    Last Post: 04-02-2004, 07:51 PM
  3. Eek! Here is another Stepper/PS question
    By CactusChip in forum CNC Machine Related Electronics
    Last Post: 02-20-2004, 04:35 AM
  4. Yup, another stepper question
    By Darren_T in forum DIY CNC Router Table Machines
    Last Post: 12-12-2003, 01:30 PM
  5. Stepper Question
    By xairflyer in forum DIY CNC Router Table Machines
    Last Post: 11-13-2003, 01:30 AM
