586,032 active members*
2,962 visitors online*
Thread: SVC-A board
    Jul 2010
    46
    SVC-A board
    Hello,
    My LS30N keeps damaging every SVC-A board I try (3 in total) after some time.
    I have even replaced complete the drive together with SVC-A board (E4809-770-015-D).
    Can I replace SVC-A board E4809-770-015-D with E4809-770-015-B?
    Is there any schematic available for this board?
    Should I check the motor? It is a BL-50E-20T.
    Michael
    Jul 2017
    50
    Re: SVC-A board
    I think I had this happen with several boards getting killed on a couple Cadet V4020 OSP 5200s.
    I had to send the damaged servo amps and motor to be repaired on request of the Hartwig tech. He said that he had only seen it a few times where a motor that otherwise shows good megger results and doesn't really have a problem with demagnetism will damage servo amps and those amps can in turn damage another motor. I sent the drives and motors to a third party repair shop. Naturally you'll have to reset the home offset after reinstallation for the axis because you're un-mounting a servo from the ballscrew.
  1. G0704 stock spindle control board to mach 3 via C32 board.
    By ballistic42 in forum Benchtop Machines
    Last Post: 09-22-2016, 02:47 AM
  2. Replies: 0
    Last Post: 11-26-2015, 10:34 PM
  3. Replacing BMU board in AMADA PEGA 357 (Instaling TULIP Fanram Board)
    By Spanish in forum Maintenance DIY Discussion
    Last Post: 11-21-2015, 02:58 PM
  4. Replies: 0
    Last Post: 11-30-2014, 05:16 AM
  5. Replies: 1
    Last Post: 06-01-2010, 05:31 AM
