586,036 active members*
4,107 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > lathe turning, steps to achive final size
Results 1 to 6 of 6
    May 2019
    3
    Welcome all,
    I am working in machining shope for few years and operate and program mills and lathes.My question is related to turning procedure to achive tight sizes up to 0.025 microns.I have never been showne how it should look like. Basicly I dont have scraps, but when big job is coming I am always worry to make it right.Spend hours serching on internet with no results. Can someone give some guide with how much for finish pass, how many finish passes etc.
    Thanks Marcin
    Dec 2013
    5717
    Re: lathe turning, steps to achive final size
    0.025 microns? Do you actually have a machine that will hold that tolerance? And have very accurate temperature control? And do you have a method of measuring that close?
    I think grinding or lapping would be required for that accuracy.
    Jim Dawson
    Sandy, Oregon, USA
    May 2019
    3
    hi, I turn such a part for a while. I have machine and measurment equipment, dont have temperarure romm control.I would like to know what other machinist aproach is to achive good resoults and have 100% to get size what you are looking for.
    May 2019
    3
    Dec 2013
    5717
    Quote Originally Posted by sacro View Post
    One finish pass should be enough. Depth of cut and feed speed depends on the material. Warm your machine up before trying to hold close tolerance. Use very sharp tools. Make test cuts to dial the machine in for the job and adjust tool offsets as needed.
    Jim Dawson
    Sandy, Oregon, USA
    Sep 2006
    6463
    Just run some wet and dry on the back of your 12" ruller until you think the size is good......BTDT.
  1. Mach 3 - correlation between steps per MM and size of the table
    By Stnq in forum Mach Software (ArtSoft software)
    Last Post: 02-07-2016, 02:04 PM
  2. Replies: 10
    Last Post: 02-05-2016, 01:29 PM
  3. Need Help - Final steps before movement
    By JTMRMC14 in forum DIY CNC Router Table Machines
    Last Post: 01-13-2012, 05:29 PM
  4. T1 Universal QT10 lathe...FINAL FRIGGEN STRAW
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-23-2008, 04:02 AM
  5. Progressively milling to final size
    By davejpc in forum G-Code Programing
    Last Post: 11-08-2007, 11:38 AM
