586,398 active members*
3,032 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Can't get servos to run....
    Sep 2005
    221
    I have some new servo motors, Leedan I believe, and I have them tied
    to new amc analog drives, I have used these same motor with amc digital drives with no problems. The amp has a test mode in which no input from the
    controller card is required, and the amp has a pot that you can turn back and
    forth which is supposed to be used to verify that the motor turns back and forth as well. The more you turn the pot, the faster it goes in that direction,
    turn it the other way, and it slows down and reverses direction etc.
    I have talked to amc tech support and they had me check hall input and that appear o.k.. They had me switch the motor leads to all six combinations and
    none work properly.. About the best it does is vibrate more in one direction
    than others.
    Anyone have a similar problem? Any thoughts? I am really stuck!
    24223
    See your other post on the subject.
    Al.
    Albert E.
  1. Servos ?
    By deleteallusers in forum Servo Motors / Drives
    Last Post: 02-17-2007, 12:09 AM
  2. Help With Servos
    By Biggermens in forum Servo Motors / Drives
    Last Post: 02-01-2007, 04:57 AM
  3. AB servos
    By macgeek10 in forum Gecko Drives
    Last Post: 06-10-2006, 12:03 PM
  4. where to buy servos
    By dgalaxy in forum Servo Motors / Drives
    Last Post: 06-02-2006, 03:50 PM
  5. AB servos
    By macgeek10 in forum CNC Machine Related Electronics
    Last Post: 05-28-2006, 05:05 AM
