587,030 active members*
3,626 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Wantai SS880 closed loop stepper drive tuning
    Jun 2009
    33
    Hello !
    Has anyone had any luck connecting to the Wantai SS880 for tuning , with their software WANT_HBS_Pro_turn ?
    I have the cable which is the same as for the Leadshine and other drives, on one smaller drive from Longs HBS57 I can connect and set the tuning parameters.
    As always manufacturer in this case is of little help. These drives are from ACT but re branded. None of the Pro turn software ACT Longs or Wantai is abel to connect to these SS880 , and all connect to HBS57.
    What I sometimes get is that the fields get randomly filled with number 19 , but that is all.
    Jan 2013
    5
    Re: Wantai SS880 closed loop stepper drive tuning
    Have you had any luck with these? I was thinking on getting these with 12nm nema 34 closed loop. But since I see your having issues I may stick with leadshine from fast to buy.
    Jun 2009
    33
    I returned the whole batch that was ordered 10pcs and received new ones , these are ACT drives but with a fan inside heatsink ,
    They work flawless
    Aug 2019
    13
    Quote Originally Posted by danilom View Post
    They work flawless
    You returned the wantai SS880? What did you end up getting?
    And from where?
    I'm just about to order them from ebay and told the seller I will buy only if they work with the software, otherwise I will return them and they pay for shipping.
  1. Replies: 0
    Last Post: 12-17-2015, 05:27 AM
  2. Open Loop to Closed Loop Stepper Conversion
    By beamhome in forum Stepper Motors / Drives
    Last Post: 03-09-2014, 11:27 PM
  3. Emc and cnc drive.com closed loop
    By matttargett4 in forum LinuxCNC (formerly EMC2)
    Last Post: 02-28-2013, 03:53 PM
  4. Replies: 0
    Last Post: 03-13-2012, 11:15 PM
  5. Looking for a closed loop AC motor/drive combo
    By pstockley in forum Phase Converters
    Last Post: 12-06-2005, 08:40 PM
