586,035 active members*
3,814 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Avid CNC > CNCRP 48x48 Pro for machining aluminum?
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Feb 2005
    829
    Re: CNCRP 48x48 Pro for machining aluminum?
    Saw your video, congrats on your new machine!
    You should get or build a fogbuster type coolant system for cutting metal on your machine.
  2. #22
    Oct 2004
    298
    Quote Originally Posted by nlancaster View Post
    Yep, that's on the to-do list. I actually have a second head for the fogbuster on my Tormach, so I might just use that and make my own tank for it. I'm not sure how to deal with the MDF, I don't want it getting damp of course.
    YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
  3. #23
    Aug 2019
    Just saw your video can you give more info on the current proximity sensor setup. This looks different than what is shown in other images I have seen. Specifically the Y axis sensors.
  4. #24
    Aug 2005
    58
    Quote Originally Posted by cowanrg View Post
    I was originally going to get a larger CNC vertical mill, so this is actually quite a bit cheaper, so I can throw a bit more money at it to get the most out of it.
    Robert,
    Do you have any impression on your new machines on cutting aluminum in comparison to your tormach as a reference. I am curious on the speeds / depth of cut / surface finish capability.
  5. #25
    Apr 2004
    326
    Has anyone tried just using air blast for cooling rather than liquid coolant? Would love to do more aluminum, but the mess.....
  6. #26
    Aug 2017
    34
    I have the Benchtop Pro 2436 and have had no problem machining 6061.
    - - - Updated - - -
    The most I use for 6061 on my Benchtop Pro is spray lube. I usually cut it dry with ZRN-coated tooling.
Page 2 of 2 12
  1. odd stalling behavior - CRP pro 48x48 with mach4
    By Fabrik8r_K in forum Avid CNC
    Last Post: 08-03-2018, 05:27 PM
  2. Right table size for CNCRP PRO 48x48
    By cstmwrks in forum Avid CNC
    Last Post: 03-09-2015, 07:43 PM
  3. PRO 48X48 Nema23 Build -Newbie
    By vinsonelt in forum Avid CNC
    Last Post: 12-12-2014, 05:51 AM
  4. Looking to build Solsylva but 48x48
    By kkester1963 in forum DIY CNC Router Table Machines
    Last Post: 06-29-2012, 04:52 PM
  5. heating source for 48x48 VF-1/4 ABS
    By edwardpic in forum Vacuum forming, Thermoforming etc
    Last Post: 06-21-2007, 09:36 PM
