586,070 active members*
3,390 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > looking for a 6ta master board a20B-0007-0010
    Sep 2006
    18
    :wave: I have a wasino lenuc j lathe with a 6t control on it and I keep getting a 911 alarm randamly After talking to fanuc they said that it sound like the master board is going bad so my question is does anyone have a board around I just replaced my spindle drive and I'm hoping that someone can help???
    Jan 2007
    333
    I searched alt.machines.cnc in google groups and found many threads on 911 alarms with many causes/remedies. I'd hate to see you buy the board unnecessarily. Do a search here at CNCzone also.
    HTH
    Sep 2006
    18
    Thanks for the response I found that dumping the memery might help would you happen to know how to do this on a 6t-a control????
    Jan 2007
    333
    Make sure you have a list of the original parameters (not the ones currently in the control). I'm not sure of the procedure, maybe someone else who knows for sure will chime in. The older controls had the PWE (parameter write enable) toggle switch on the mainboard in the electrical cabinet. Something about holding in "Reset" and "Delete" keys during powerup, or something like that. This is not for beginners so take care and be sure.
  1. CNC Master
    By Paul in OK in forum Benchtop Machines
    Last Post: 11-15-2006, 08:13 PM
  2. Master Machinists
    By djbowser in forum Employment Opportunity
    Last Post: 08-30-2006, 05:10 PM
  3. OUCH: 0.0007% Error rate not acceptable
    By Geof in forum Haas Mills
    Last Post: 07-02-2006, 04:09 AM
  4. How well does master cam
    By johnm in forum Mastercam
    Last Post: 06-02-2003, 05:06 AM
