586,388 active members*
3,204 visitors online*
    Aug 2011
    21
    how to change time and date
    hello,can anyone let me know how to change the date and time in LCNC.thks
    Dec 2005
    596
    Re: how to change time and date
    You can do it from either the command line or the GUI. For the command line either man date or man rdate. The GUI should be self explanatory. What version of Linux are you running?
    Mark
    Aug 2011
    21
    hi,i believe the version is 4.8.6.I did try the command line but did not success, because i am new to linux.can you let me know where can i change the date and time from the GUI.thks.
    Dec 2005
    596
    Look under the "System Settings" for "Date and Time."
    You probably need to use 'sudo' to use date or rdate from the command line to change the date and time. Type "man sudo" for an understanding on how sudo elevates your privileges on the system to enable system changes.
    Mark
    Aug 2011
    21
    hi mark,i will give it a try,thks.
  1. VF2 How to set time and date?
    By RBrandes in forum Haas Mills
    Last Post: 07-15-2013, 08:27 PM
  2. Anyone know how to set the date and time on a T32-2 controller?
    By mattme in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-29-2008, 10:49 PM
  3. Setting of Time/Date at QT8
    By weedy in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-26-2008, 08:01 AM
  4. Date and Time Variables?
    By broby in forum Okuma
    Last Post: 12-11-2007, 11:12 PM
  5. How to set the time and date
    By DomB in forum Haas Mills
    Last Post: 03-11-2007, 12:03 AM
