586,080 active members*
3,625 visitors online*
    May 2019
    Threading on CNC Lathe no longer working
    Hello,
    I have had a cnc lathe for quite a few months now (About 8). I have a product that I produce and the threading is no longer working on it. I was curious if anyone would be able to lead me in the right direction. Basically it's a G76 threading cycle and it's wiping the threads out now. It just started doing this and we've been running this part for about 6 months now.
    Dec 2013
    5717
    Re: Threading on CNC Lathe no longer working
    Spindle encoder index pulse problem? Or spindle encoder problem in general?
    Jim Dawson
    Sandy, Oregon, USA
    May 2019
    We just had the encoder replaced. What is a pulse problem? I'm very new to this.
    Dec 2013
    5717
    The index pulse is a once per revolution pulse from the encoder, normally labeled ''I'' or ''Z''. Depending on how your controller works, it may use this pulse for locating the start point of the threading cycle.
    Jim Dawson
    Sandy, Oregon, USA
    Jul 2017
    50
    I don't know if a slipping belt would also cause this problem.
  1. Replies: 0
    Last Post: 01-19-2015, 10:37 PM
  2. working projects longer than the machine parameters
    By nagginwitch in forum Material Machining Solutions
    Last Post: 01-13-2015, 11:13 PM
  3. Dolphin Lathe: Threading finishing path not working
    By harry4516 in forum Dolphin CAD/CAM
    Last Post: 09-12-2013, 12:28 PM
  4. Threading cycle in 0i-td not working
    By Harmeet in forum Fanuc
    Last Post: 05-19-2013, 09:25 PM
  5. lathe threading working
    By ljd10 in forum Mach Lathe
    Last Post: 04-21-2011, 03:33 PM
