586,060 active members*
4,275 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > z80 cpu alarm .....not what Hitachi says it is and ladder load
    Aug 2007
    138
    looking at my manual and misc doc they have, they say "replace the master board"
    Well not necessarily. More likely is you lost your ladder and or have garbage in there. My battery was not really dead, showed 2.85 volts but ladder was a mess.
    I went through the entire initialization of my VK45. Cleared/erased everything. Loaded new ladder. Still have lots of errors on the screen and PC not ready. Some of the errors said something to the effect of PARAMETER 023,044,...blah blah.
    Loaded a good parameter set, now down to one error -- pallet something...cleared it and reboot. Finally have a not ready screen and she starts and runs pretty well. have not done a full run program test but zeros XYZ and spindle changes gear fine and M3, M4 and M5 work
    tomorrow, I have to reset the carousel position and next/ready tool, check my "set tool length" location and prob several other things need tuning as well
    Aug 2021
    10
    Re: z80 cpu alarm .....not what Hitachi says it is and ladder load
    hi Dan, thank you very much for the post.
    i have the same error,
    can i have you email please?
    Aug 2021
    10
    Quote Originally Posted by Dancy View Post
    you mentioned "Loaded a good parameter set" after loading new ladder.
    Wondering what kind of parameter set it was?
    was the parameter set different from the Fanuc parameter set?
    or the parameters were Fanuc parameters?
    Bob
  1. Hitachi Seiki VM40 ladder back up
    By mnankov in forum Hitachi Seikis
    Last Post: 10-22-2022, 12:31 PM
  2. Replies: 13
    Last Post: 02-05-2014, 04:05 PM
  3. Hitachi_seiki vk45 load ladder
    By vin27 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-09-2013, 03:48 PM
  4. Ladder for Hitachi Seiki HT-15
    By stump1189 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-10-2011, 12:56 AM
  5. Missing pc and Ladder files for the Hitachi seiki hicell ca 20
    By Rinus in forum CNC Machining Centers
    Last Post: 09-19-2008, 03:45 PM
