586,104 active members*
3,366 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > Kuka robot arm milling help
    Jan 2016
    Hi ,i would like to buy used kuka robot arm that will be used for milling granite and marble stone ,like kitchen countertops ,and have a few questions if you can help please . is kuka kr210 good enough with krc2 controller? what kind of spindle motor will be ok is atc 9kw enough for milling and is powermill cam software enough by itself ,thank you very much !!
    Sep 2020
    Re: Kuka robot arm milling help
    Sharp & Fellows, Inc. has been in business as a railroad contracting company since 1877. Specializing in railroad track construction, maintenance, inspection and lubrication, design, demolition, and special projects. Our main goal is to continue to exceed all customer expectations and railroad service needs. With two locations to better serve you in Los Angeles and San Bernardino, our company is the right one for you.
  1. Kuka robot servo drive wiring
    By MarcNach in forum Servo Motors / Drives
    Last Post: 12-07-2018, 01:41 PM
  2. Robot kuka for 3d milling? Opinions !!!
    By fozletra in forum Uncategorised WoodWorking Machines
    Last Post: 01-17-2017, 03:37 PM
  3. Looking for consultant to help set up a rotary table with a Kuka robot arm
    By neeboy in forum Uncategorised CAM Discussion
    Last Post: 08-30-2013, 12:18 PM
  4. Looking to buy used KUKA or ABB industrial robot for 3D milling
    By Olga_R in forum Want To Buy...Need help!
    Last Post: 12-06-2011, 11:53 AM
