586,065 active members*
4,218 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > PathPilot 2.2.2 Pulsar
    Jan 2016
    386
    I have been using PathPilot 2.0.0 since Brian Posted his files back in December '17 without any issues. Today, I decided to connect the internet to the mill to save running around with the usb drive. Well if you run PathPilot you know you activate the internet in the status tab. There is also a big <<UPDATE>> button right there. So I decided to update to v2.2.2. Copied all the required files to their respective locations and now PathPilot errors out. I poked around for a while but never did figure it out. I reverted back to v2.0.0 and all is fine again.
    Just wondering if any of you running PathPilot 2.x have run into this? Which updates have you applied with without issues?
    Steve
    Jan 2016
    386
    Re: PathPilot 2.2.2 Pulsar
    So I went and installed PathPilot's 2.x updates incrementally and found you can safely update to version 2.1.5. PP v2.1.6 is where the the problem starts.So I will stick to version 2.1.5 until I have a chance to review the log file. PP v2.1.6 added support for the door lock switch which might be causing the problem.
    Steve
  1. PathPilot 2.x and PathPilot Simulator
    By draper-ballou in forum Tormach PathPilot™
    Last Post: 01-01-2019, 01:42 AM
  2. PathPilot 2.0 - Working on Novakon (Pulsar)!!
    By brianbonedoc in forum Novakon
    Last Post: 04-03-2018, 03:07 PM
  3. Replies: 5
    Last Post: 04-29-2017, 10:09 PM
  4. New Pulsar on its way!
    Last Post: 04-04-2016, 02:02 AM
  5. Pulsar is here!
    By ivans in forum Novakon
    Last Post: 01-11-2014, 10:49 PM
