586,036 active members*
4,437 visitors online*
    Sep 2005
    273
    Milltronics ramping
    Hello, this is a 2003 vm25 with Milltronics Centurion 7 control, when I use the clear pocket for a slot and tell it to ramp for Z it does a helical circle at the Z depth of cut? and if I change the ramp angle it dont change, what am I doing wrong? also it does the helical circle on the edge of the slot and will leave a witness mark, sometimes I dont want to run a finish pass and just rough to size, is there a way to change this? thanks
    Sep 2005
    273
    Re: Milltronics ramping
    Nothing? ok how about this, does anybody know were the spindle bearing purge drain hole is and how to check if its working?
  1. Ramping V24
    By zachf in forum BobCad-Cam
    Last Post: 01-26-2012, 11:32 PM
  2. Ramping down
    By dazzer in forum Bridgeport / Hardinge Mills
    Last Post: 11-29-2008, 02:26 AM
  3. ramping
    By truefordlover1 in forum BobCad-Cam
    Last Post: 08-01-2008, 06:28 PM
  4. Ramping
    By pauls in forum BobCad-Cam
    Last Post: 03-04-2005, 10:49 PM
  5. Ramping example?
    By inthedark in forum G-Code Programing
    Last Post: 04-10-2004, 02:53 PM
