586,119 active members*
3,615 visitors online*
Results 1 to 3 of 3
    Oct 2015
    6
    MX4660, Home, Limit micro-switch
    Hi All,
    I recently purchased a MX4660 driver for my DIY cnc
    The motors are running perfectly.But I stuck at Home & limit switch configuration (i'm using micro switch)
    there are some pins named input1, input2,................ input8
    but i don't know how to interface this with Mach3 software
    any leads will be really appreciated
    Thanks,
    Mirza
    Mar 2007
    2083
    Re: MX4660, Home, Limit micro-switch
    when connecting to the 4 limit switch inputs and E-stop on the first printer port or motion controller port
    this may help assuming your using a 12V supply for the limit switches
    Attachment 421406
    and do not need to add resistors to use higher voltages - see figure 15 on the manual page 16
    PDF manual
    Attachment 421404
    assuming your using mach3
    in pins and ports - input signals
    you need to assign port 1
    pin 10 as X limit ,
    pin 11 as Y limit
    pin 12 as Z limit
    pin 13 as X limit
    pin 15 as E stop
    John
    Oct 2015
    6
    Hi John,
    Thank you very much for your help!!
    I got the Point!
    :banana::banana::banana:
  1. MACH 3, Warp9 smooth stepper, Leadshine mx4660 Limit switch home switch woes HELP
    By cabinman in forum Mach Software (ArtSoft software)
    Last Post: 01-14-2018, 08:26 PM
  2. CNC 11, Micro Switch Home setting.
    By howanc7 in forum Centroid CNC Control Products
    Last Post: 10-17-2015, 05:57 AM
  3. simple micro limit switch wiring question
    By nateman_doo in forum Benchtop Machines
    Last Post: 12-18-2010, 11:24 PM
  4. MICRO Adjustment of Lever Type Limit Switch
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 05-16-2007, 02:47 PM
