586,068 active members*
4,091 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > X,Y,and Z motors will not work
    Hello all. I am totally new to this CNC world. I bought a cheap Chinese CNC I think it is a woodpecker 3018 . After I assembled and got things sliding as smoothly as I could I tried to fire it up with my laptop and controller board etc
    all I heard was the motors trying to work but all I heard was noise on all three motors. I disconnected the screw leads bars from X and Y motors and tried again with the same results. Do I have a problem with the motors or is my problem with the controller board . any help would be appreciated
    Ron
    1943
    Re: X,Y,and Z motors will not work
    The woodpecker board uses Grbl firmware that controls the motors. The program on your PC is just an interface for Grbl. Do you know what the Grbl settings are and can you post them here?
    Ok my settings for the GRBL cntl are as follows Com5 and 115200 . I have set the com in device manager to com5 so now what I get when I fire this up
    1- with the screw leads disconnected on both X and Y motors when I try and run them I get the whining noise but nothing turns I even tried to set the preset to 10 same results
    2- when I start the spindle at say 900 it seems to work just fine the spindle up and down work the same as X and Y lots of noise but no movement I also moved the screw lead coupling out about 1/8 inch out from motor
    same results . Now the fact that things seem like they should work tells me that the board appears to be working and maybe it's maybe a setting that's incorrect
    1943
    Quote Originally Posted by clake4341 View Post
    Those are not your Grbl settings The settings I'm talking about are the $$ settings
    I not sure this is what you are looking for but I copied this from GRBL setting
  1. Will these stepper motors work?
    By SteveC68 in forum Hobbycnc (Products)
    Last Post: 12-13-2017, 10:59 PM
  2. I Need Help Getting My Motors To Work
    By Kickin Wing in forum Benchtop Machines
    Last Post: 04-30-2015, 12:20 AM
  3. Stepper motors don't seem to work :-(
    By winand in forum CNC Machine Related Electronics
    Last Post: 03-05-2014, 09:07 PM
  4. How do I work out what motors I need
    By Methias in forum Stepper Motors / Drives
    Last Post: 07-02-2009, 02:36 PM
  5. Will These Work (Stepper Motors)
    By Hawkeye in forum DIY CNC Router Table Machines
    Last Post: 12-06-2003, 06:53 PM
