586,094 active members*
3,926 visitors online*
    Dec 2018
    9
    How to zero return / home axis meldas 500
    Hi, I am all new to cnc machining, but I am trying hard to learn. I have bought a dyna myte 4400M milling machine, with a meldas 500 control. I have figured out how to move the axis with the habdle and how to program with the MDI edit. However i get a P430 AXIS NOT RET error, which seems to be because the machine has not been homed after restart. How do I do this? The control panel has a mode switch which can be set to "zero return", but I have no idea what to do after turning this switch and I cannot find any explanation in the manual. I also have 2 flip switches saying T.L.M and PLAYBACK, can anyone explain what these do?
    Attached Thumbnails Attached Thumbnails 47EC3D9B-8BCD-4BD4-A547-23FCF1D13489.jpg   8FF33640-132A-437C-B596-1605A33998D2.jpg
    Aug 2009
    1573
    Re: How to zero return / home axis meldas 500
    Try setting "Zero Return" mode than Push and hold any XYZ or 4th button, until the Light goes ON...might be the "+" or "-" button...
    Quote Originally Posted by diaowee View Post
    The machine seems quite old, it is better to have a user manual to learn first before operating it, in case something wrong happen.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Dec 2018
    9
    Quote Originally Posted by machinehop5 View Post
    This worked perfectly! Thank you!
    Any ideas on how to use the T.L.M mode? I guess it has something to do with tool length measurement? And the playback-switch?
    Dec 2018
    9
    Quote Originally Posted by cncmakers001 View Post
    Hi, I have the user manual, its 700pages and not very well written, so its hard to understand much from it. Just a easy thing like homing the axis was impossible for me to understand from the manual.
  1. Go to G30 - return to home positon
    By Uman in forum Tormach Personal CNC Mill
    Last Post: 09-10-2015, 09:26 AM
  2. MELDAS M3 cant reach zero home Z axis
    By damm in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-24-2013, 08:06 PM
  3. MELDAS M3 cant reach zero home Z axis
    By damm in forum Mitsubishi controls
    Last Post: 02-06-2013, 01:19 PM
  4. Unable to Zero Return / Home all axis on Matsuura MC-1000VS Mill
    By aaronthoj2000 in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2012, 11:11 PM
  5. 18i-TA zero return (home referencing)
    By padobranac in forum Fanuc
    Last Post: 03-18-2009, 09:31 PM
