586,076 active members*
3,757 visitors online*
Thread: TNG Progress
Page 6 of 6 456
Results 101 to 104 of 104
  1. #101
    Mar 2017
    1312
    Re: TNG Progress
    M73 restores modal state. If tool offset was not active before measuring then it will remain inactive. To activate it correctly call G43.1.
    I will update tool measure script in next release scheduled for Friday to use M70/M72 instead of M73 and activate offset again with G43.1 after M72.
  2. #102
    Oct 2016
    5
    Re: TNG Progress
    Quote Originally Posted by PlanetCNC View Post
    Ok, thank you, this is a good explanation. but your default script alredy ends with this sequence:
    G43.1
    M2
    and the docs on M73 (Store and autorestore) says:
    "[...] If program ends with M2, M30 or % modal state will not be restored"
    But, as stated before, the modal state get restored (ignoring M2) and so G43.1 is discarded...
    So, please double check the doc and/or the implementation of M73 because something is wrong.
    At the moment, enable tool offset with g43 or g43.1 at the start of the scripts seems to me an effective solution.
    Bye
    MrBlue
  3. #103
    Mar 2017
    1312
    Re: TNG Progress
    Nice catch.
    Modal state store/restore used to work only in subprocedures and M73 autorestore worked only on "endsub".
    State store/restore now works regardless of subprocedures and if state is stored in "main" level it is also restored on program end. This can be very useful.
    Default script uses M43.1 at the end which is correct. Incorrect is that it uses M73. It should use M72 and M70 just before second G43.1 line.
    I already fixed it for next release. Now I will also fix documentation for M70 codes.
  4. #104
    Oct 2016
    5
    Re: TNG Progress
    Nice catch.
    Perfect! Thank you. Looking forward for next release soon
    Bye
Page 6 of 6 456
  1. progress
    By 1hander in forum Benchtop Machines
    Last Post: 02-24-2016, 04:00 AM
  2. more progress..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 03:56 AM
  3. Progress at last
    By RustedOut in forum Charter Oak Automation Support Forum
    Last Post: 10-16-2010, 05:13 PM
  4. My first CNC... in progress!
    By hi-tech in forum CNC Wood Router Project Log
    Last Post: 06-02-2009, 10:45 PM
  5. progress! (pix)
    By anthony in forum Waterjet General Topics
    Last Post: 06-03-2005, 10:56 PM
