586,043 active members*
3,885 visitors online*
    Jun 2017
    Help with first CNC Lathe Purchase
    Hello - I own a rather large fab shop that mostly deals with commercial framing and accessories. We have about a dozen press brakes, a fiber laser, punch presses, a few shears, 4 rollformers, etc. About a year ago we were approached by one of our customers to mill some aluminum parts so I bought 3 Haas mills and off we went. Since then I've been machining all kinds of parts in addition to making dies and repair parts for our other equipment. I had no idea what I was doing but have been around machines of various types all my life and took to it fairly quickly.
    Now this company wants parts that need to be turned so I need a lathe. I want something that can definitely do these but also has the capability to make parts for our machines that we have had to sub out in the past.
    The parts that for sure are required are .75 round 6061 with a thread at one end and some grooves. Some are 5" long some are 10". They also have some holes in them that I can either use live tooling with a 90 or set up in the mill. Obviously would prefer to do it with one set up.
    I have about $40k to play with so I am going used obviously. Bar feeder would be a big plus or at least the ability to add one.
    I would be happy to hear any suggestions.
    Hey. The use of CNC lathes for metal is very important for large-scale and mass production, because everything that a machine does automatically, a conventional machine cannot do. Changing tools, changing cutting modes, automatically turning on coolant, moving a caliper - all these procedures would have to be done manually on a conventional lathe. Each of these procedures is performed manually many times in the conditions of mass production of any part - a small loss of time.
    Jul 2019
    Hey! We may have what you are looking for! Send us a message at your convenience and one of our experts can help you out!! In the meantime, check out our huge inventory of machines at affordable prices. I will put a link that will send you right to our CNC Lathe inventory!
    https://revelationmachinery.com/collections/lathes
    I hope this helps!
  1. New lathe purchase
    By DLF in forum Mini Lathe
    Last Post: 05-12-2022, 04:28 PM
  2. Considering purchase of a new lathe
    By dsdmax in forum Hardinge Lathes
    Last Post: 03-15-2011, 07:25 PM
  3. First lathe purchase, please help!
    By davidmc in forum Want To Buy...Need help!
    Last Post: 12-13-2009, 10:18 AM
  4. Which lathe should we purchase
    By Lathebuyer in forum Uncategorised MetalWorking Machines
    Last Post: 02-26-2008, 06:56 AM
  5. which CNC lathe to purchase?
    By msomerville in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2006, 11:53 PM
