586,051 active members*
3,824 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Sterling Silver - Turning (lathe) speed and feed rate suggestion
    Nov 2015
    371
    Can someone suggest turning speed and feed rate for sterling silver?
    I intend to turn some very small parts with intricate details on a mini tabletop lathe using carbide tools.
    Apr 2004
    5737
    Re: Sterling Silver - Turning (lathe) speed and feed rate suggestion
    Without knowing the diameter of your sterling parts, it's hard to specify spindle speeds or feed rate. As diameter increases, the spindle speed should go down, all other things being equal. What you need to control for is surface feet per minute at the tool tip to calculate feed rates. Is this a CNC lathe you're planning to use? I looked online, but couldn't find any specific recommendations for sterling silver in any of the usual tables, probably because it's not usually machined this way. But it cuts similarly to copper (difficult and gummy); any speeds and feeds that work for copper should work about the same for sterling.
    If you want to save yourself some grief, turn the parts in machinable wax and have them cast in silver by a jewelry casting house. That way you'll save a lot of time you'd lose trying to recover those valuable chips from the depths of your machine...
    Andrew Werby
    Website
    Nov 2015
    371
    awerby, thank you for responding!
    I searched online extensively for specific numbers but I couldn't find any. I found some speeds and rates for mills. Unfortunately nothing for lathes. Casting silver has its own problems - porosity, warping etc.
    I need these parts turned with very high precision. It is not going to be as easy as turning steel or aluminum but I know it is doable. There are many online stores offering turned silver jewelry. Naturally, they are very secretive about the technology they use. As you suggested working with copper is probably similar however I am hoping someone with knowledge in this field would be willing to suggest cutting rates form his/her personal experience.
    Yes, I am going to use a small CNC lathe with precise spindle speed control.
  1. cutting **** of 1mm sterling silver
    By DecoupART in forum Want To Buy...Need help!
    Last Post: 08-29-2016, 02:44 AM
  2. CNC Sterling Silver Designs
    By hhjj7777 in forum MetalWork Discussion
    Last Post: 07-15-2015, 09:22 PM
  3. Which laser to cut 1.5 to 2mm sterling silver sheet?
    By altaran in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-08-2014, 08:56 AM
  4. Machining Sterling Silver
    By Exodus8931 in forum MetalWork Discussion
    Last Post: 11-08-2009, 03:45 PM
  5. suggestion, feed,speed,DOC on hastaloy,monel and 316
    By ambrose in forum MetalWork Discussion
    Last Post: 11-19-2007, 04:13 PM
