586,217 active members*
3,003 visitors online*
Results 1 to 6 of 6
    Jun 2019
    4
    HAAS Mini Mill Question
    Hello all,
    I am looking at the mini mill and it says at the website that it operates on single- or three-phase power (three-phase power is required for some options). My question is what are the options that require three phase?
    Nov 2012
    145
    Re: HAAS Mini Mill Question
    No idea I have a year old TM1P with most options and the 4th axis and single phase is fine.
    Feb 2018
    17
    If I remember right, its the high-flow coolant pump.
    15362
    Quote Originally Posted by mmarmino View Post
    Hello all,
    The supermini mill needs 3Ph and any with a different spindle motor from standard motor
    Mactec54
    Nov 2012
    145
    I believe you are right the super’s spindle has the higher rpm requiring 3 phase, I have the high pressure coolant it’s single phase.
    In my understanding, some type of spindles or coolant pumps needs three phase powers, to clarify this, you must contact supplier. In case of 1 phase requirement, there are limited choices.
  1. Haas mini mill newbie question
    By markypete in forum Haas Mills
    Last Post: 09-17-2015, 11:08 AM
  2. haas mini mill question
    By magnum500sw in forum Haas Mills
    Last Post: 02-23-2013, 06:38 PM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  4. HAAS MINI MILL Question (I'm pulling my hair out)
    By Powder_Keg in forum Haas Mills
    Last Post: 09-19-2008, 03:09 PM
  5. Haas Mini Mill Programming Question
    By CuttingTools in forum Haas Mills
    Last Post: 05-24-2006, 02:44 PM
