586,060 active members*
4,160 visitors online*
    189
    ESS upgrade problem
    Upgrading an older machine from parallel port to ethernet SS. Got everything hooked up and so far as I know the 'puter is talking to the SS board. I can toggle the e stop led on and off in mach (3).
    Not getting any movement out of any of the axis.
    DRO in mach will go up and down as commanded by keyboard but no movement at the steppers.
    The led lights next to the pins on the SS do not change state while attempting to move and of the axis.
    The leds on the SS all come on when powering up the SS without connected to mach. Once Mach is running they go out.
    Any ideas?
    Thanks!
    Is a sentance fragment?
    May 2019
    6
    Re: ESS upgrade problem
    Is the IP address correct? That would be the first thing to check.
  1. v25 ucs problem after 996 upgrade
    By 2jzs4rx7 in forum BobCad-Cam
    Last Post: 08-03-2013, 11:10 PM
  2. Pc upgrade problem Help needed
    By cristian gabor in forum Mach Software (ArtSoft software)
    Last Post: 05-13-2013, 05:22 AM
  3. Upgrade problem.
    By TheBigJW in forum Mastercam
    Last Post: 10-08-2010, 03:58 PM
  4. Spindle Drive Upgrade problem
    By levelzero in forum Tormach Personal CNC Mill
    Last Post: 11-11-2009, 12:08 PM
  5. Partner 1, Centurion 5 upgrade problem
    By lotsa luck in forum Milltronics
    Last Post: 12-21-2007, 04:11 AM
