586,069 active members*
3,629 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Milling Polycarbonate 14mm discs or plugs?
Results 1 to 1 of 1
    Jun 2019
    Question Milling Polycarbonate 14mm discs or plugs?
    Hi All -
    I'm new here and need some help on the feasibility of milling some polycarbonate plugs. My current method of production is turning down 5/8" Polycarbonate rod on a lathe and then parting. These plugs are backed by a carbon fiber plate (2mm) and it's time consuming to part, glue backing, clean up, then part again.
    I've attached a picture of the final product for reference.
    I'd like to be able to CNC mill a sheet of the carbon plate backed Polycarbonate but I'm not sure if this is even doable.
    Specs:
    Each Plug final dimensions should be 14mm in diameter and approx 11mm in thickness.
    Any input is greatly appreciated.
    Thanks,
    Phil
