586,069 active members*
3,690 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Avenger 200C fault and some strange things...
    Jun 2019
    Hi all,
    I bought a Cincinnati Milacron Avenger 200C lathe, with (strange) part cather option, but without any manuals... It have some trouble...
    1. On booting all tests are passed and "Host control initialize" is flashing. After a few turn off, or reset the machine is wake up.
    2. When the machine is wake up, there have 2 fault message: W-AXIS circuit fault, Alarm number 00453. When i push the alert reset/data reset, after Alert number is: 19099.
    My questions:
    1. Where can i get manuals?
    2. How can i solve that problems?
    The controller is Acramatic 850SX, the servos are Siemens 6SN611.
    I did change the drives and motors already and the fault message is same.
    Thank You and sorry for my poor english.
    Jul 2009
    8
    dear mm440
    Did you find the cause of the problem?
    I'm having the same problem. please help me.
    I am having trouble for turning the cincinnati Acramatic 850sx control panel.
    my motor drive is siemens.
    SUMP off
    DIMP off
    GMEM red
    DAMP red
    RUN yellow
    OSA red
    MMC red
    SERV off
    PCA red
    DPWR green
    APWR green
    Display SYSTEM START-UP HOST CONTROL INITIALIZING
    then there is no movement. waiting for help for this problem. thank you
  1. G540 always in fault - red LEDS - strange voltages
    By GTFreeFlyer in forum Gecko Drives
    Last Post: 12-24-2013, 04:54 AM
  2. SLAmstepper doing strange things....
    By racedirector in forum Open Source Controller Boards
    Last Post: 10-08-2012, 11:34 PM
  3. Strange things happening here in Maine!!!!
    By Barefootboy4 in forum Mach Software (ArtSoft software)
    Last Post: 01-27-2011, 12:01 AM
  4. puma 200c Qsetter
    By alllen in forum Daewoo/Doosan
    Last Post: 01-03-2008, 10:29 PM
