586,071 active members*
4,344 visitors online*
Results 1 to 6 of 6
    May 2017
    5
    Inverter Fault
    Keep getting "System Interrrupt: Inverter Fault".
    Machine has a Yaskawa GPD 506/P5 Inverter.
    I am sure the dust in cabinet hasn't helped, have cleaned out cabinet and inverter but problem seems to be gradually getting worse. Used to happen once a day and now it happens every couple sheets I cut.
    Any suggestions would be great.
    Dec 2013
    5717
    Re: Inverter Fault
    The real question is: Is it a real fault, shown on the inverter display, or does the controller just think it's getting a fault signal from the inverter? The former may be a problem with the inverter, the latter could be just a loose wire.
    Jim Dawson
    Sandy, Oregon, USA
    May 2017
    5
    Re: Inverter Fault
    The Inverter is showing EF3 - Ext Fault 3
    I did check to make sure all the terminals were tight on the inverter. Next I guess I should probably check the whole panel for loose wires.
    Dec 2013
    5717
    Re: Inverter Fault
    That being the case, I would check the electrical diagrams to see what terminal triggers an external fault on the inverter. Then follow that wire back to the source.
    Jim Dawson
    Sandy, Oregon, USA
    Re: Inverter Fault
    Quote Originally Posted by Cabmaker View Post
    Change a new inverter would be the solution, because if keep showing the error and stop the production is time wasting which means losing money.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jun 2010
    463
    Re: Inverter Fault
    What wire is going to terminal 3 on the inverter?
    And what model machine do you have?
  1. Replies: 8
    Last Post: 04-23-2019, 02:32 PM
  2. fadal 3016 inverter fault error
    By Runner4404spd in forum Fadal
    Last Post: 04-21-2012, 03:51 AM
  3. GURU NEEDED: Inverter Fault (OL2)
    By StephenSebastia in forum Multicam Machines
    Last Post: 09-28-2011, 07:18 AM
  4. Inverter fault / Drive line fault ?
    By TMILLS in forum Fadal
    Last Post: 10-21-2010, 03:20 AM
  5. inverter done after #9 fault
    By logos in forum Fadal
    Last Post: 03-22-2006, 03:53 PM
