586,068 active members*
3,876 visitors online*
    CNC Router for routing Carbon fibre
    Hello!
    I'm currently in the process of designing a CNC Router for routing carbon fibre. I need help in selecting a spindle for the same.
    I have thought of going with Bosch GKF125CEN Palm Router - 1.25 HP. I wanted to check if anyone has used this spindle for machining carbon fibre and also is the torque and power of this spindle sufficient to machine carbon fibre?
    Would love to get a reply for this ASAP!
    Thank you for your time in advance!
    Regards
    Soundharya
    Feb 2005
    829
    Re: CNC Router for routing Carbon fibre
    AFAIK that is the bosch colt router. they are hit or miss on bearing quality, this can cause excessive spindle play.
    - - - Updated - - -
    I know alot of people have had good luck with this one
    https://www.amazon.com/DEWALT-DWP611-Torque-Variable-Compact/dp/B0048EFUV8/ref=pd_lpo_sbs_469_t_0?_encoding=UTF8&psc=1&refRID=2BS4JCT3VEWTHZ13D1XH
    1227
    Do make an effort to provide very good extraction when machining carbon.If it gets into the important parts of the machine there will be cackling and sparking and maybe much worse.It is even more important if the carbon has been autoclave cured as the fibre fraction is higher.
  1. What setup to cut carbon fibre sheet (uk )
    By xchipx in forum Composites, Exotic Metals etc
    Last Post: 01-06-2017, 02:21 PM
  2. Carbon FIbre (1.5mm) CNC Routing
    By jeboa in forum EUROPE RFQ's
    Last Post: 04-06-2012, 03:12 AM
  3. Can EDM wire cut Carbon Fibre material?
    By gunsmither in forum EDM Discussion General Topics
    Last Post: 04-14-2009, 11:48 AM
  4. Routing Carbon fibre laminate
    By kong in forum Composites, Exotic Metals etc
    Last Post: 04-09-2007, 05:08 AM
