587,058 active members*
3,685 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Lexan Window Thickness
Results 1 to 11 of 11
    Feb 2013
    89
    So upon getting my over-the-garage door storage built in my garage, one of the support beams had a meeting with the front window of my VMC40. Didn’t seem like it took much to shatter it so it is probably best to replace them anyways. I’m going to buy some Lexan to replace them. What thickness is the Lexan from the factory? I don’t want to go off of the Windows I’m replacing because I don’t know if they are the “correct” thickness.
    Dec 2013
    5714
    Re: Lexan Window Thickness
    I would use 1/4 inch. Pretty tough stuff. I think 3/8 inch Lexan will stop a .45 ACP round point blank.
    The way that window broke would indicate that it is not Lexan, but rather is acrylic. Not the best choice for impact resistance.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2013
    89
    Yea. Couldn’t have been more force than an average guy’s punch.
    Feb 2013
    89
    What do you think about tempered and laminated glass?
    Dec 2013
    5714
    Quote Originally Posted by NismoGT View Post
    The only advantage I would see is that would be more scratch resistant. But the impact resistance of Lexan is greater, and it may be less cost. I've not had any problems with the plastic windows in my lathe or mill. The lathe is 30 years old and the windows are still fine, but I don't know if they are original. The mill is only 2 years old and I know they are original. Not sure what the material is in either of them, but if I needed to replace them it would be with Lexan.
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2019
    12
    I plan on upgrading my to 3/8 with new bolt in pieces. I can readily get lexan, just haven't gotten there yet. Just would make me feel way safer.
    Jun 2010
    4256
    Lexan, NOT glass and NOT perspex.
    1/8" or 3/16" would be fine. It's a window, not a crash barrier.
    Cheers
    Roger
    Jan 2015
    417
    Fadal uses 3/16 Lexan you could also use 1/4 if you want even better. Fadal at first did use Tempered Glass on the first version of Full enclosure sheetmetal 1988 (you dont see many kinda rare but they had actual sliding doors on sides not the pull out panels). They went to Lexan when one of the Tempered panels shattered at a customers. Customer said "I was watching the part being machined and then all of a sudden *POP* the Glass disappeared"
    Feb 2013
    89
    Quote Originally Posted by rodney247 View Post
    Yea that’s why, if it were the route I was taking, what have used the *laminated* tempered glass rather than just standard tempered glass.
    Feb 2013
    89
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    I’m certain that all walls around the machine have to be “crash barriers” even if it’s transparent.
    Oct 2008
    1638
    I installed 3/16" Lexan from local homeless depot because that's the thickness that was in there.. I think 1/4" will tighten up in there better because the 3/16" clamped okay but not real snug. 1/8" will be a very loose fit.
    48 in. x 96 in. x 0.187 in. Polycarbonate Sheet $130 #206792207
  1. Looking for CNC Cut of Lexan Panel
    By Mark30504 in forum RFQ (Request for Quote)
    Last Post: 07-28-2014, 05:16 PM
  2. Pines Numbers 3&4 Benders Frame Thickness and Nose Thickness
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 02-04-2010, 04:59 AM
  3. finishing Lexan
    By qmas99 in forum Material Machining Solutions
    Last Post: 07-02-2007, 01:45 PM
  4. saw slitting lexan
    By recoton in forum Glass, Plastic and Stone
    Last Post: 07-02-2007, 10:54 AM
  5. Tricool TC1 and lexan
    By ckhalford in forum Benchtop Machines
    Last Post: 05-20-2007, 10:47 PM
