586,058 active members*
4,275 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Alarm EX1012 IN THE TOOL CHANGE AREA (Fanuc Robodrill ?-T21iFa)
    May 2018
    26
    I tried turret restore procedure but get another Alarm OT0500 (Z)+ OVERTRAVEL (SOFT 1) during restore procedure.
    Dec 2015
    171
    Re: Alarm EX1012 IN THE TOOL CHANGE AREA (Fanuc Robodrill ?-T21iFa)
    confirm the system number first then if you have original parameters of machines find stock limit parameters,after put the values in system parameters.
    also check conditions like door close,gaurd close,z axis interlocking parameters etc.
    Feb 2012
    126
    I think you may have reset the turret, but the head is up too high in Z and is in the area normally reserved for tool change. This can happen when interrupt a tool change in progress. I pulled my hair out for a week when it first happened to me. I think there is a procedure outlined in the machine book for a "Manual return" Mine is an older control and may be a little different. Let me know if this helps point you in the right direction.
  1. Tool library . Fanuc Robodrill w/ 31i b5
    By jacobjust in forum Fanuc
    Last Post: 05-24-2017, 12:33 PM
  2. FANUC ROBODRILL T10B - LOST TOOL CHANGE PROGRAM
    By 9-Fingers in forum DNC Problems and Solutions
    Last Post: 08-30-2016, 02:04 AM
  3. Alarm during tool change on a Bridgeport BPC 320H with Fanuc 6MB11
    By Leblondmakino in forum Bridgeport / Hardinge Mills
    Last Post: 02-08-2014, 02:03 PM
  4. Replies: 1
    Last Post: 02-08-2013, 12:05 AM
  5. Replies: 1
    Last Post: 07-31-2006, 06:19 PM
