586,213 active members*
3,330 visitors online*
    Jun 2014
    611
    Laser Cut a Wooden Spongebob Model
    Today I am telling you how to make A Spongebob. Making Sponge Bob is easy! All you need is 5 mm plywood and a designs. Now is going to use a Thunder Laser system to make a Sponge Bob. Let’s start to explore fun with the laser!
    Aug 2018
    28
    Re: Laser Cut a Wooden Spongebob Model
    It looks very good.
    It would be great if you shared the cut file in vectors for the community.
    regards
    I am an experienced laser technician.
    User of laser cutting machine Buchicnc EVO 14.
    User of laser recorder EVO 5.
    CNC router user, with 3 x 2 m table Auto Tool Changer
    I usually design my own laser files designs for laser cutter & laser engraver with CorelDraw, Laser Cut 5.3, RDWorks V8.
    Laser cutters & CNC Routers BuchiCNC USA
    CNC Router ATC
    EVO 14
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
  1. Laser/Engraver Model CNCWL-1390N-80 Watt Laser
    By CNC-Warehouse in forum For Sale Only
    Last Post: 06-30-2016, 08:03 PM
  2. laser cutting wooden box
    By AmyThunderlaser in forum Thunder Laser
    Last Post: 05-06-2014, 08:42 AM
  3. Laser Scanning of hand carved wooden Corbel
    By Khalid in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 09-21-2010, 08:47 AM
