586,565 active members*
3,862 visitors online*
    Jun 2003
    242
    YASNAC MX-3 communication errors
    I'm having some issues with downloads to the YASNAC MX3 control on my Matsuura 510V. This is the typical start of a program for me:
    O200 (OFFSET FLANGE)
    G17 G20 G40 G49 G80 G90
    G00
    G91 G28 Z0.
    G91 G28 X0. Y0.
    T15 M06 (3/8 SPOT DRILL)
    G90 G54 X-2.0771 Y1.4831 T14 S955 M03
    The problem I'm having is that almost always the G40 G49 G80 in the second line transmits as G4000, G4080 and occasionally G40 G80. It's also read the G54 as G5 a couple of times and missed a decimal once. Are these hardware problems or possibly setting issues between the PC and CNC?
    Another issue is that it won't download sub programs, it stops at any M30 or M99, M99 is a problem as I don't have the macro function so any looping has to be done with M99, is that a parameter setting?
    Any help would be appreciated!
    Jun 2003
    242
    Re: YASNAC MX-3 communication errors
    Changing download program solved the problem
  1. Errors 122 and 175
    By grc in forum Haas Mills
    Last Post: 07-30-2015, 08:38 AM
  2. Replies: 4
    Last Post: 07-08-2013, 06:02 AM
  3. Errors 190 and 192
    By luisreynoso in forum Milltronics
    Last Post: 02-14-2013, 01:45 AM
  4. Communication errors
    By Smokio in forum Fadal
    Last Post: 10-07-2012, 12:56 AM
  5. Replies: 4
    Last Post: 02-15-2012, 04:52 PM
