586,070 active members*
3,598 visitors online*
Page 1 of 5 123
Results 1 to 20 of 86
    Jul 2013
    230
    Vetric Aspire nose dive on Z Axis
    I’m making a simple dish shape sanding surface.
    For the first 1/5 of the rough cut, it runs great then suddenly drops in Z and everything gets off kilter.
    The PRZ is off.
    I’m not sure if it’s software or a hardware issue.
    I’m running a KL 1212, Mach 3 and in this case Vetric Aspire.
    Please help
    Aug 2018
    621
    Re: Vetric Aspire nose dive on Z Axis
    Quote Originally Posted by robwiacek View Post
    The PRZ is off.
    Please help
    You can check Vectric off the list of possibilities your cam file isn't going to cause a sudden drop unless you programed the part that way.
    As far as what the cause is it could be a lot of things you're just going to need to do some reading based on your components. I would suggest giving more information including pictures of your machine along with a video of the problem so you can get help. Otherwise your going to get a bunch of guesses and you will have a hard time getting good information.
    Dan
    Jul 2013
    230
    I know that’s right.
    But I went and ran a program that is steady Eddie for me and NO problems occurred.
    I opened up the controller housing, blew out any dust.
    Tomorrow, I’ll check all mechanical connections.
    I even went and searched the Gcode but found nothing abnormal.
    I guess I’ll re-run the program and video it.
    Aug 2018
    621
    I hear you it's tough to troubleshoot when it's intermittent like what it sounds like you are dealing with. I've seen guys replace all their steppers and drives for AC servos and it turned out to be the Cncpc was causing the problems with 3d vectric files. I would assume that wouldn't be your problem since you're using a laser cutter correct? I don't know enough about laser cutters to know what would cause the head to nosedive into the material.
    Jul 2013
    230
    No it’s not a laser. Just a simple cnc router with a 1/2” ball nose bit.
    Other programs run fine! Just this one.
    Maybe I’ll blow out the Pc maybe dust is a problem. Who knows?
    Jun 2010
    4256
    Try running at half the feed rate. If that solves the problem, you know how to tackle it.
    Cheers
    Roger
    Jul 2013
    230
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    That will be painfully slow, but it’s worth it.
    I never set the feed rate in Aspire. In Mastercam, I do all the time.
    Thanks for the tip.
    I’ll give it a try.
    Don't reduce the feedrate.
    Reduce the maximum velocity and acceleration settings in the control.
    You're most likely losing position on Z rapid moves, and the feedrate won't affect rapid moves.
    If you never set a feedrate in Aspire, then you are using the default feedrates, which may be totally inappropriate for your machine. Either way too high, or, way too low.
    Jul 2013
    230
    Where are those located?
    It makes sense what your saying, but I’m not really sure where to find the settings to manipulate.
    Are they in Mach 3 or on the Aspire tool path section?
    Mach3. Config > Motor Tuning.
    Jul 2013
    230
    Thanks man!
    I’ll give it a shot.
    Aug 2018
    621
    Oh I kinda thought it was a router but you posted in a laser engraving forum. Can you post screen shots of the Aspire file showing the tool path info along with the part rendering? Btw the feeds and speeds are in the tool setup in Aspire. You need to make sure you have the proper chip load for your tooling setup, the default settings more than likely won't be right. Is it a 3d machined part.? You might want to start a thread on vectrics forum if you are only having issues making parts with aspire. Have you machined similar parts with Mastercam with out issues?
    Sep 2005
    1740
    Quote Originally Posted by Ntl View Post
    Ditto, we had over 20 pages posted on the Vectrics Forum a few weeks ago and it ended up being mostly user error. Just about exactly the same thing as here. User did not understand basic CNC flow pattern or G Code and we spent a lot of time on his issue.
    Jul 2013
    230
    I’m pretty versed in G code and cnc speak.
    Not sure why I posted it to the laser site.
    I’ve written and corrected codes before while working in Mastercam X5.
    But this is just odd.
    I went back and ran programs done in Mastercam and no problem.
    So this is just weird.
    It’s s 22” diameter dish in MDF.
    It’s only about .25” deep in the center, and as I said I’ll get 1/5 or do through it then it’ll drop the Z then everything is off.
    The PRZ is no where near it’s original position.
    With a .5” ball nose bit, it takes so long just getting to that point. I don’t really want to slow it down. But I might run it again and try to find the exact line of code it freaks out on.
    Thanks for commenting.
    Jul 2013
    230
    I’m going to check the parameters in Vetric and see what it is.
    But do you thinkMDF has any real effect on the 1/2” ball nose?
    It basically pulverized the material.
    BTW I did look for those posts.
    I think I found them. But what I do look out was fine tuning the machine in Mach 3
    Calibrating the 3 Axis’s
    Oct 2011
    66
    Quote Originally Posted by wmgeorge View Post
    When mine did it on one design and worked on all the other I searched for days and did air cuts and it still did it. after a week of searching I discovered that the Z axis had sawdust on the bottom of the rails and had packed in hard enough to stop the axis.and the z would position thinking it was higher than it really was when it retracted. oh yeah I made a few holes in the spoil board and projects. now I watch that area carefully.
    Jul 2018
    6339
    Hi Rob - Does Vectrix have a toolpath simulation? If you can simulate the toolpath and its not in there then its mechanical. Peter
    Correct. If it's not in the Aspire preview, then it's most likely not a problem with the code.
    And if the Z axis has lost position, the g-code can't cause that to happen.
    Jul 2013
    230
    These are some great reply’s.
    I’m better to navigate on Mastercam where I can review the G Code to see if there are weird moves. Not sure if I can review the codes.
    So, I’ll clean up the terminals and inspect the wiring and the ball screw.
    I do agree that it’s not a software issue, but can it be an operator issue?
    I mean, I’m only cutting MDF with no sudden moves.
    It’s a simple bowl, 22” Diameter and not quite .25 deep.
    Thanks for your help.
    Jul 2013
    230
    Yes it does, but not sure if you can view the G Code
Page 1 of 5 123
  1. VETRIC ASPIRE - TROUBLE
    By forbri40 in forum Aspire
    Last Post: 01-24-2018, 04:03 PM
  2. Vetric Aspire V CNC
    By KWK in forum Commercial CNC Wood Routers
    Last Post: 09-14-2017, 10:18 AM
  3. Aspire from Vetric vs. Aspire from Alphacam
    By jooooooe in forum Aspire
    Last Post: 06-04-2015, 04:52 PM
  4. setting up tool in vetric aspire
    By ttharp in forum Uncategorised WoodWorking Machines
    Last Post: 03-02-2014, 12:56 AM
  5. Rotary axis - NcStudio - Aspire
    By Nidge888 in forum Chinese Machines
    Last Post: 04-05-2012, 04:13 AM
