586,108 active members*
3,069 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 2100 x axis don't align
    Hi everybody, I have a problem with acramatic 2100. When I make procedure for align all axis they Machine make the alignment procedure, but at finish never align the axis, however all axis movement. I try disable only X axis, and the procedure for align successfull, then I try enable only X axis (y and z disabled) and never move the axis, when I use JOG mode X axis move on both directions. Acramatic 2100 never show errors and I don't know what is the problem.
    Oct 2016
    106
    Re: Acramatic 2100 x axis don't align
    Hi. Maybe it's the switch under work table. Remove x guards , locate it, do align procedure , press that switch during alignment and see if machine goes other direction, or alarms overtravel ( there are 2 switches).
    Sent from my D5803 using Tapatalk
  1. Arrow 500 Acramatic 2100 X AXIS TPA/HOME FAILURE
    By AGEMACHINERY in forum Cincinnati CNC
    Last Post: 12-05-2019, 08:47 PM
  2. Acramatic 2100 X axis Servo Error
    By Wildman05 in forum Cincinnati CNC
    Last Post: 03-28-2019, 01:31 PM
  3. acramatic 2100 - Z axis not ready overtravel limit
    By Madom in forum European Club House
    Last Post: 11-27-2017, 12:43 AM
  4. Replies: 0
    Last Post: 03-21-2011, 01:33 PM
  5. Axis command on Siemnes Acramatic 2100
    By kevinuk32 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-29-2009, 12:41 PM
