586,110 active members*
3,409 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > 6040 error code and spindle not working. Help!
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Mar 2018
    18
    Re: 6040 error code and spindle not working. Help!
    Well I ended up just getting a new VFD and will run the spindle manually.
    But I don't know how to program it for my spindle. Any help?
    Spindle info:Power: 1.5KW
    Voltage: 220V
    Frequency: 0-400HZ
    Speed: 0-24000RPM
    See pics for the VFD manual.
    Hopefully someone can help me. I changed a couple of parameters that I thought might be the way to go and tried it. The spindle starts up and spins but quickly (1 second) gives me an error 1 (short circuit/current overload/power module protection). So obviously didn't do it right.
  2. #22
    15362
    Quote Originally Posted by ericks View Post
    Thanks....i need to see all the terminals to make out the writing. Also need to see any switches on the pc board
    You are looking at them in this photo show them clearly, that is the complete open board VFD Drive these machines have Power in Power out to spindle it's all connected correct, the only thing missing is the Ground wiring which is normal for these machines, which need to be rewired with Ground wires
    Programing is usually what these machines have problems with
    Mactec54
  3. #23
    15362
    Quote Originally Posted by Gom View Post
    Voltage: 220V
    Frequency: 0-400HZ
    Speed: 0-24000RPM
    Is this an AT1 Drive need the Drive Name Spec's
    Mactec54
  4. #24
    Mar 2018
    18
    Aiight. I got it working. Thanks to those who tried to help.
    I will upload my current parameters later in case anyone else finds this thread in the future.
Page 2 of 2 12
  1. Replies: 1
    Last Post: 06-04-2018, 01:21 PM
  2. Chinese 2.2 kw VFD and spindle error code
    By AmparoTech in forum Maintenance DIY Discussion
    Last Post: 10-19-2012, 01:09 AM
  3. Spindle error code 35
    By Desertrunner in forum Fanuc
    Last Post: 04-22-2012, 10:56 PM
  4. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  5. 404 spindle error code
    By Michael Turner in forum Knee Vertical Mills
    Last Post: 02-08-2011, 09:41 AM
