586,096 active members*
3,012 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > How to connect a DDCSV offline controller to a Huanyang 2.2kw VFD?
Results 1 to 8 of 8
Threaded View
    Jun 2019
    29
    New to these forums and CNC (Sorry if I posted this in the wrong spot) but would really appreciate it if anyone could give me some helpful advice on how to connect a DDCSV offline controller to a 2.2kw water cooled spindle so as to turn the spindle on and off as well as control its speed. I thought if I followed the manual I would be fine but I am a bit overwhelmed by all the parameters. I have the spindle working and the offline controller controlling all the stepper motors but I cannot get the two cooperating.
    The offline controller is a RMHV3.1 rebranded DDCSV2.1 offline controller on Amazon:
    https://www.amazon.com/RATTMMOTOR-Li...gateway&sr=8-6
    RMHV2.1/3.1 Manual (same as the DDCSV's):
    https://drive.google.com/file/d/0B49...J5a1dRTGs/view
    Offline Controller Spindle Settings:
    98 maximum spindle speed: 24000.000 rpm
    219 If Stop Spindle when pause: Yes
    220 Spindle speed selection: G code
    221 default spindle speed: 12000.000 rpm
    222 Spindle commands M3/M5 response: Yes
    224 Spindle M3/M4/M5 response Duration: 5.000 s
    227 Spindle switch Active Level: High
    422 definition of PWM Electric level: Low
    433 PWM rising rate from 0V to 10V: 310
    The VFD is a Huanyang 2.2kw VFD intended for 110V to power a 8.5A Spindle on Amazon:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Huanyang VFD Manual:
    http://www.jinlantrade.com/ebay/invertermanual.pdf
    Huanyang VFD Program Settings:
    P000: 0
    P001: 2
    P002: 2
    P003: 400.00
    P004: 400.00
    P005: 400.00
    P006: 2.5
    P007: 0.5
    P008: 110
    P009: 13.0
    (It's a pretty long list but most of it should be factory default)
    My wiring schematic (stepper motors and pendant work fine as far as I can tell):
    [If it's too hard to see from the pictures]
    From the offline controller to the VFD:
    M3/M5 --> FOR
    GND --> ACM
    VSO --> V10
    I'd be pretty grateful for any help!
