586,065 active members*
4,517 visitors online*
    Jun 2019
    Chinese GRBL Board End Limit Switches
    Good morning,
    I'm a new member of this forum and this is my first CNC build. I have assembled a TopDirect CNC Router from Amazon, everything works fine after about 8 hours of building.
    I have mounted Micro Limit Switches, Left and right on the X Axis, Front and back on the Y Axis and only 1 at the top of the Z Axis.
    The Limit Switches have Normally Open and Normally Closed pins on the bottom and a Common pin on the side.
    I have found many and varied diagrams for wiring them together in series, but my problem is that I have 3 pins to input to on the X Y and Z Limit pins on my Chinese Woodpecker (?) board.
    The X-Limit, Y-Limit Z-Limit and Serov inputs (which I assume should read Servo?) all have + - and S marked on them.
    Every other diagram for wiring limit switches to a Chinese Woodpecker Style board suggest only a + and - connection.
    Can anyone please offer advice on how I should wire/connect my limit switches?
    There is a picture of the board attached.
    Many thanks,
    Adam
    Apr 2005
    304
    Cool Re: Chinese GRBL Board End Limit Switches
    GRBL needs NO switches.
    On x and Y axis they should be in parallel.
Name:	Screenshot from 2019-06-17 02-13-31.png
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Jun 2019
    Many thanks for your help.
    This is my first foray into circuit diagrams since school, 30 years ago, so I may come back with a few questions after I've looked at your diagram in detail.
    1943
    NO switches are more prone to noise. Using NC switches is really no harder. All you have to do to use NC switches is invert the input in Grbl settings.
    Apr 2005
    304
    Quote Originally Posted by 109jb View Post
    And to add some resistors
    Should read the code, it is very well documented/commented.
  1. 6040 4 axis Chinese CNC - Installing Limit Switches help
    By chris190 in forum Chinese Machines
    Last Post: 05-06-2019, 06:04 AM
  2. Chinese USB 3020 Limit Switches
    By Mr Sprue in forum CNC Machine Related Electronics
    Last Post: 12-27-2017, 01:08 AM
  3. GRBL freezes when I turn on limit switches
    By norbert1998 in forum Arduino
    Last Post: 05-26-2017, 11:09 AM
  4. Replies: 0
    Last Post: 04-22-2015, 10:05 PM
  5. Chinese cnc 3020 limit switches and spindle pwm .
    By RusDemka in forum CNC Machining Centers
    Last Post: 11-27-2013, 02:03 AM
