586,060 active members*
4,149 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > What is the best way to learn how to optimize a CAM program's parameters?
    Jun 2019
    5
    Question What is the best way to learn how to optimize a CAM program's parameters?
    What is the best way to learn how to optimize a CAM programs parameters? Are there textbooks on optimizing CAM software parameters? I am looking for commentary on every parameter a piece of CAM software would have. Mastercam's tutorials, for example, do not go into detail at all about the why behind a parameters. The help file will only give a one line explanation. CAD is something else entirely, you can experiment with functions and figure things out that way and there are much more textbooks on the subject. Why are there next to no CAM textbooks...?
    Dec 2013
    5717
    Re: What is the best way to learn how to optimize a CAM program's parameters?
    The reason for no textbooks is that every CAM program is different. Most CAM software has tutorials available, but sometimes the explanations are a bit lacking. Normally the way I do it is to set up what I think will work then run a simulation to see if the toolpath is what I want. Then change the parameters and run another simulation to see what changed. Sometimes you have to trick the program into doing what you want, depending on the software.
    If you're asking about feeds and speeds, there are too many variables to give even general rules. You can get guidelines from the tooling manufacturers catalogs, but those guidelines generally apply to rigid, high HP machines. If you machine(s) doesn't fit that criteria then you have to make adjustments for feed, speed, DOC, and step over.
    Jim Dawson
    Sandy, Oregon, USA
  1. do you wantto learn mastercam 5 axis program
    By asmanss in forum News Announcements
    Last Post: 05-13-2016, 10:53 AM
  2. Program optimize
    By vesene in forum Okuma
    Last Post: 04-06-2016, 03:10 PM
  3. Best way to optimize my program
    By jeffrey001 in forum Mastercam
    Last Post: 01-25-2012, 07:44 PM
  4. Free cad program that I can learn on?
    By MidShipCivic in forum Uncategorised CAD Discussion
    Last Post: 08-11-2008, 04:14 PM
  5. What's the best cam/cad program to learn first ?
    By Yakkis in forum Uncategorised CAM Discussion
    Last Post: 11-13-2007, 11:58 PM
