586,036 active members*
4,343 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > drawing threads in bobcad v27
Results 1 to 8 of 8
    Feb 2017
    12
    I been trying to put threads on a 3d drawing of a shaft in bobcad. I found a thread library but cant find out how to do this. I'm not using this for a lathe or milling operation, just trying to make a drawing of some inside and outside threads in bobcad for an .stl file. I have seen videos on other cad programs but not on bobcad. Any help would be great.
    Thanks Gary
    Re: drawing threads in bobcad v27
    It's possible but you need to use 3d modelling techniques to build your thread geometry, I've never needed to model a thread as I make parts not pictures ;-)
    Feb 2017
    12
    Quote Originally Posted by magicniner View Post
    The end result will be a part but i have to draw it first and then get a G-code to send to the machine. No drawing no G-code. Thanks Gary
    Quote Originally Posted by ggeh View Post
    Thread a piece of stock in the simulation and export the finished part as a 3D model.
    If you are 3D printing BobCAD isn't the best thing for it, I use Blender for 3D modelling for 3D printing, it handles meshes better.
    May 2013
    701
    Thanks Gary
    I have done it in V27 but it is a lot of steps
    Had to draw an inner and out spiral and then the thread profile and break it in halves and attach it to the spiral and then skin and then add all surfaces together
    much easier to just drag a part in from another program.
    RAF
    Feb 2017
    12
    Thanks for the info. Ill see if I can find Blender and take a looksee. Thanks Gary
    Feb 2017
    12
    Quote Originally Posted by RAF. View Post
    RAF
    That sounds complicated beyond my knowledge of bobcad. I was thinking I just missed something because I seen a thread library and assumed some where I would enter the thread size and pitch and be done, just didn't know how to go about it. Bobcad seems like such a powerful cad program I would of thought it would be a copy and paste. I purchase a cnc plasma table in 2014 and bobcad is the cad program it came with , so that's what I been doing my 2D drawings on. I just got a 3D printer and seen I could save my drawings as .stl files so rather than learning a new cad program I that I would try using Bobcad for the 3D geometry also.
    Well thank you very much for the how to explanation.
    Gary
    That's for cutting threads, not building models ;-)
  1. Need some help in BobCad drawing in 3d
    By ggeh in forum BobCad-Cam
    Last Post: 06-19-2019, 12:12 AM
  2. Bobcad drawing
    By robyn123 in forum BobCad-Cam
    Last Post: 02-27-2015, 01:03 PM
  3. Replies: 5
    Last Post: 10-31-2012, 02:44 AM
  4. Drawing Threads in Solidworks
    By the war ninja in forum Uncategorised CAM Discussion
    Last Post: 07-12-2005, 04:59 PM
