We have a Premier Plasma CNC Table with a Miller Spectrum 625 X-treme attached to it and a Proma Compact THC Controller SD. Everything is working fine except when cutting thin materials or materials that are warped. Our issue seems to be that once the head’s height is set at the beginning of a cut, it doesn’t adjust if the material is unlevel or warped through the cut and it stops cutting.
My main question is, can someone confirm that the Proma Compact THC Conntroller SD is capable of auto-setting the head’s height while cutting? If not, what THC controller do I need in order to get automatic touch sensor.
