586,104 active members*
3,250 visitors online*
IndustryArena Forum > CAM Software > Vectric > z axis creeping
    Oct 2012
    17
    z axis creeping
    Hi. The Z motor (dc servo) does not hold the position while cutting.
    I noticed on a belt that the motor is retracting during operation and as a result, the axis is raised a few mm in the end.
    Apr 2004
    5737
    Re: z axis creeping
    Could the encoder be loose on the motor shaft? If it was moving relative to the motor, the servo system would rotate the motor to compensate.
    Andrew Werby
    Website
    Oct 2012
    17
    Re: z axis creeping
    ok. i will check. (there are a lot of vibratons) . It is symptomatic that the Z axis always creeps UP.
    Spindle cable is separated ....
    I grounded the "servo control casing", but not the machine ...
    Oct 2012
    17
    Re: z axis creeping
    Solved !
    the encoder was slipping in the motor shaft. ccc
    Thanx to awerby :-)
  1. Z axis current creeping up and alarming
    By peloflex in forum Mitsubishi controls
    Last Post: 11-13-2016, 06:22 PM
  2. Axis's creeping away...
    By nickcornilsen in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-06-2013, 06:03 PM
  3. Z Axis creeping
    By RustedOut in forum Charter Oak Automation Support Forum
    Last Post: 09-26-2012, 06:56 PM
  4. Z axis creeping up!
    By MAX711 in forum Mach Software (ArtSoft software)
    Last Post: 07-13-2006, 12:33 AM
  5. Problem with Z Axis creeping up
    By HansM in forum DNC Problems and Solutions
    Last Post: 09-10-2005, 04:16 AM
