586,035 active members*
3,556 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > artcam 1325 Chinese cnc 220v problem
Results 1 to 7 of 7
    Nov 2011
    13
    Hi, no info came with it, ask saller still watting.
    Well my main panel have the neutral and ground in common.
    I use a 30amp breaker 2 phase to fee the cnc controller.
    Attach images.
    When I turn the breaker at controller the contact won't engage, I manually engage, the vfd power up and the inverter at bottom not power up , I read 17vac at input ???
    Any advice.. thank you.
    Sep 2005
    1740
    Re: artcam 1325 Chinese cnc 220v problem
    On the first picture I think I see L1, L2,L3? If so that is markings for a 3 phase power input, which you do not have. The other lead with spiral tape should be marked Green or Green Yellow is that machine ground? Picture of the machine nameplate would be nice.
    Nov 2011
    13
    hi, that's what i was thinking at first when i saw the L1 2 3 on the top of the screw-bar but the tech who sold me the machine say to connect l1 and l2 to power up but its not ..
    at top of the bar i see a blue wire and red tougher (neutral and hot)?? can't be , maybe the label wrong ??? i hate to take all the wire out to figure out where the go ...
    p.s. the green tape wrap its the ground coming from the panel. my neutral its connected to the ground at main panel.
    Sep 2005
    1740
    Quote Originally Posted by magnetos2010 View Post
    Look at and take a picture of the machine data plate. I bet it says 3 phase.
    FYI Chinese single phase wiring is one hot and another wire they call neutral but its not a grounded neutral like we use. The green or green and yellow wire is machine equipment ground. Your getting neutral and the ground confused. The Chinese 220 v does not use our neutral.
    Nov 2011
    13
    the machine its Artech 1325R, still await info from the Chinese engineer ???
    Sep 2005
    1740
    You do not need an Engineer, Post a picture of the machine nameplate!!
    Nov 2011
    13
    hi, solved . the tech told me by Skype what wire was in the wrong place, works now . Time to carve parts. thank you.
  1. Wiring Chinese 220V power in US
    By PIVOTALCUSTOMS in forum Servo Motors / Drives
    Last Post: 05-12-2019, 05:17 AM
  2. Replies: 0
    Last Post: 03-14-2015, 05:30 PM
  3. Anyone in auckland with a chinese 1325 CNC router?
    By jasonharris22 in forum Australia, New Zealand Club House
    Last Post: 02-09-2012, 08:36 AM
  4. 2.2KW 220v Chinese spindle on 208v 3ph?
    By MechanoMan in forum DIY CNC Router Table Machines
    Last Post: 12-06-2011, 04:49 PM
  5. chinese 220v help
    By bpoulin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-25-2011, 10:17 PM
