586,069 active members*
3,484 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Bridge design for raised x Axis cnc
    Aug 2018
    29
    Hi I am about to build a CNC machine to cut wood and foam. The design has a raised x-axis. The focus is put on speed and less on the ability to cut harder material like aluminum. sizes are 4m x-axis, 1,4m y axis and 0,25m z axis. X and Y uses a rack and pinion drive z axis a ballscrew combo. The combo is screwed on a 0,4m x 0,25m aluminum plate. Now I am considering how to build the bridge? As my focus is put on fast cutting I would like to build the bridge as light as possible. To keep costs down I would prefer to build it from steel. Do you have any suggestions?
    Sent from my MI 6X using Tapatalk
    Jul 2018
    6339
    Re: Bridge design for raised x Axis cnc
    Hi Flexbex - I'm designing a kit router with gantry that would suit your build. Read the Maximus thread in the forum may give you some ideas. Peter
    Aug 2018
    29
    Oh great thx looks very promising. But will take a while to go through 270 posts :-)
  1. H-Bridge Design
    By dakimber in forum LinuxCNC (formerly EMC2)
    Last Post: 08-29-2012, 10:08 PM
  2. design and machining raised letters
    By compfranon in forum Uncategorised CAM Discussion
    Last Post: 09-10-2010, 03:49 PM
  3. H-bridge Servo Driver design
    By EMMKAY in forum Servo Motors / Drives
    Last Post: 03-03-2009, 11:24 AM
  4. mosfet h-bridge design
    By visky in forum CNC Machine Related Electronics
    Last Post: 06-11-2008, 09:51 PM
  5. Fixed Bridge CNC Router design
    By Helstrom in forum DIY CNC Router Table Machines
    Last Post: 12-08-2007, 08:14 PM
