586,999 active members*
3,092 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Post Processors for MC > Minor changes to Generic Fanuc Posts....
    Feb 2006
    202
    So, I've been able to change a good deal of the post processor to suit my shops preferences. A couple things I'm stuck on:
    It outputs a G17 in the first line, and a G20 in the second line. Since the CNC we have defaults to that anyway, can I remove these from the post sequence? If so, how?
    And at the end of the program, my partner wants to see:
    M5
    G91G30Z0.M9
    G28Y0.
    M30
    It's currently giving me a G30 Z0 on the first line, but the next line is G30 Y0....
    Also, is there a way to have N numbers ONLY on the toolchange? My partner has worked a certain way for a LONG time. He is used to seeing:
    N10 T1 M6
    N20 T2 M6
    N30 T3 M6
    so on and so forth......
    Seth
    Sep 2003
    35
    I am not a post genius, but if you look in "psof" there should be a line that sayes"pbld, n, *smetric, e" that is your G20.
    And in the following line that should be a "*sgplane" that is your G17.
    HTH
    Lars
    Mar 2006
    1013
    If it doesn't matter, why do you want to bother with it? What if someday you want to run a program metric? Now you'll have to put it back in. If it works leave it alone.
    Lets say you want to start a program where the first cut is in the XZ plane. Now you'll have a problem again. Those codes are there for a reason.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
  1. Replies: 33
    Last Post: 02-24-2010, 10:39 PM
  2. rolled ballscrew minor diameter?
    By ged in forum Linear and Rotary Motion
    Last Post: 12-03-2006, 08:48 PM
  3. BobCAD posts vs. Mastercam posts
    By justCNCit in forum BobCad-Cam
    Last Post: 08-16-2006, 08:17 PM
  4. Tri-power minor problem
    By bherr in forum Shopmaster/Shoptask
    Last Post: 05-19-2006, 01:21 PM
