586,058 active members*
4,468 visitors online*
    Aug 2013
    14
    Help request for Techsoft Lasercam A2 (2008)
    I can't seem to find the information i'm looking for in other threads, so i'm hoping for some assistance, or pointers in the right direction.
    Is it possible to re-calibrate the machine without having to hire a technician to come to site? Its spent 5 hours in the back of a van, and likely in need of a good service, i'm currently in the process of cleaning up the insides.
    Is it possible to connect this device to the network with a cheap USB/Parallel print server, or using the internal RJ45 socket on the control board (there is a secondary socket on a flying lead along with a PS/2 and VGA cable)
    Attachment 422900
    Many thanks
    Ben
    Mar 2005
    15
    Re: Help request for Techsoft Lasercam A2 (2008)
    USB/Parallel print server .... drivers online for free at https://www.techsoft.co.uk/Download
    do you have a manual? I need the color codes used in the print driver.... there are 8 colors... black, red, green, blue, ... but there are oranges and browns that I need the RGB code to... any help appreciated. cheers
    Aug 2013
    14
    Quote Originally Posted by davidwest View Post
    Sorry for the very long delay in responding, I've not been around here often.
    The color codes are the following
    Color - RED - GREEN - BLUE
    BLACK - 0 - 0 - 0
    RED - 255 - 0 - 0
    GREEN - 0 - 255 - 0
    YELLOW - 255 - 255 - 0
    BLUE - 0 - 0 - 255
    MAGENTA - 255 - 0 - 255
    CYAN - 0 - 255 - 255
    ORANGE - 255 - 128 - 0
    Aug 2013
    14
    Been a while since posting here, but to answer my own question.
    This device uses FreeDOS as its operating system, located on a compact flash card.
    The VGA and PS/2 connector can be used for terminal viewing, and in its default mode renders a copy of the LCD display (in the top left corner of the VGA display), and also network connector can be used to connect to a print server/SMB network share.
    However to activate the required functionality, the Compact flash needs to be connected to a PC, and the config file edited to enable network functionality
  1. Techsoft CAMCUT / Multisoft Robotique F1000 router circa. 1995
    By Lotus23C in forum Education - Teachers and Students Hangout
    Last Post: 03-10-2018, 09:44 PM
  2. Newbie Techsoft F1000 CAMCUT machine
    By Lotus23C in forum CNC Machine Related Electronics
    Last Post: 02-03-2018, 02:09 AM
  3. Duet - techsoft mill design software
    By Malbank in forum Benchtop Machines
    Last Post: 06-19-2017, 11:14 AM
  4. Replies: 0
    Last Post: 09-07-2013, 10:28 AM
  5. Replies: 0
    Last Post: 07-16-2009, 02:50 AM
