586,069 active members*
3,321 visitors online*
Results 1 to 10 of 10
    Aug 2016
    185
    C11G Board issues
    I wanted to see if anyone else has had issues with the NEW C11G boards. I got my first one and if the PC was not in "run" condition the Relays screamed and the analog voltage was zero. I was sent a second board which still had the relay screaming. Then they sent me a third board and it worked for about a month now its doing the samething.
    Anybody else got these issue or am I just the lucky guy?
    Re: C11G Board issues
    Please tell me more. Do you have a ticket number?
    Arturo Duncan
    https://cnc4pc.com
    Aug 2016
    185
    Quote Originally Posted by arturod View Post
    Arturo Duncan
    https://cnc4pc.com
    No I was trying to see if this is my setup. This board is starting to do the samething the other 2 you sent me were doing. Can you tell me what is wrong?
    I have no idea of who this is. You talk about a problem with a C11G board that we sent. I do not recall a case of bad C11G? You talk about several boards? I have no clue.
    Arturo Duncan
    https://cnc4pc.com
    Aug 2016
    185
    Arturo Duncan
    https://cnc4pc.com
    Neil Cunningham in Charlotte NC
    I was the one that reported the screaming relay. Then you sent me a working board and now that board is starting to do as the others. I just wondered what you found and could my setup be an issue. I have had this third board for a month or so.
    I had put in ticket numbers for the other boards...
    Neil,
    YES!!! I remember you. I remember the case with a batch of boards due to a resistor out of specs. As far as I can tell off the top of my head, we replaced all those boards. What is the issue you are having now?
    Arturo Duncan
    https://cnc4pc.com
    Aug 2016
    185
    Yes you did .. but the new board is starting to do the same thing.
    Not every time but it has happened a couple of times when I started up the controller. When MACH get control the issue always stops..
    Sent from my XT1635-01 using Tapatalk
    ericks Guest
    My 11G board does the same thing....actually i am not using it any more but i did notice it when i used it from the start.
    Aug 2016
    185
    Quote Originally Posted by ericks View Post
    How old is your board
    ericks Guest
    Quote Originally Posted by truckeic View Post
    Less than six months
  1. Output connections on a C11G- MULTIFUNCTION CNC BOARD
    By CStevens6 in forum Stepper Motors / Drives
    Last Post: 04-08-2013, 01:54 AM
  2. C11G board on G0704 Conversion experiences?
    By lcvette in forum Benchtop Machines
    Last Post: 01-11-2012, 06:55 PM
  3. CNC4PC C11G BOARD
    By MegaMoog in forum Benchtop Machines
    Last Post: 05-05-2010, 09:29 PM
  4. C11G board stupid questions....
    By pete from TN in forum Benchtop Machines
    Last Post: 02-15-2010, 12:20 AM
  5. KL-B25 or C11g Breakout board?
    By technosteve in forum Automation Technology Products
    Last Post: 03-14-2009, 01:32 AM
