586,089 active members*
3,876 visitors online*
Results 1 to 3 of 3
    Total Newbie: UCCNC and Sherline CNC lathe
    Hi there...i picked up a used sherline cnc lathe 4410 + rotary table with a computer UCCNC installed, a UC100 dongle and a sherline stepper motor controller. It also came with a imach 3 p4s pendant.
    As per my title, I am a total newbie. I have used the lather manually for the last couple of months but now would like to use the cnc element to manufacture prototype parts.
    Everything seems to be working. I can move the 3 axis with the pendant and UCCNC using the step control.
    However the continuous mode does not work and I can only move each axis step by step if the step size is very small (0.001) and I increased it slowly. If I move the pendant wheel too fast, the stepper motor does not follow. The same happens if I move each axis with uccnc. It only works if I select step and step size of 0.001 and I pause between the steps.
    I was wondering if you would have any idea of what is wrong.
    35538
    Re: Total Newbie: UCCNC and Sherline CNC lathe
    First thing I'd try is remove the pendant plugin, and see if you can jog with the keyboard.
    Also note that UCCNC does not have a lathe mode, so is probably not the best choice for a lathe. Especially for a beginner.
    Thanks for the reply.
    I have removed the pendant (and disable the plugin) and can jog with the keyboard only using the step size of 0.001 and slowly.
  1. In need of some serious help! Total newbie!!!
    By NJScustom in forum CNC Machining Centers
    Last Post: 06-15-2018, 09:52 PM
  2. Another total Newbie
    By blackthorn in forum Laser Control Software
    Last Post: 08-31-2015, 03:48 AM
  3. Ok I'm a total Newbie
    By jcarver in forum Uncategorised MetalWorking Machines
    Last Post: 02-21-2013, 04:56 PM
  4. total newbie
    By matt1985 in forum Haas Lathes
    Last Post: 09-24-2012, 09:16 PM
  5. total newbie
    By peggsydaly in forum DIY CNC Router Table Machines
    Last Post: 05-24-2010, 03:58 PM
