586,341 active members*
3,542 visitors online*
Results 1 to 10 of 10
    Jun 2019
    4
    Which CNC for cutting?
    Hi
    I need to cut some kind of rubber, only 1mm thick. The machines of Click'n cut market (sign market) lack of power and can't cut reliably except if you take to big machines (Esko, summa, zund etc...) which are super expensive and too big.
    My working area: around 90*60cm (36"*24").
    There are many CNC of this size out there:
    I've noticed essentially 2: stepcraft D 840 with their new tangential knife. I think that it could eventually cut my material but this is a bit light system for little production.
    The second one is the one that I'm focusing on: HIGH-Z S-1000/T CNC ROUTER from cnc-step.com .What do you think about this CNC table according to the specs? (I'm totally new to CNC tables, but I know 3D )
    I'll put on it a tangential knife like this one :TANGENTIAL KNIFE TCM-4 https://www.cnc-step.com/tangential-...-module-tcm-3/
    Do you think that this set up is enough for my need? Is this a rigid enough table to do little production?
    Thank you in advance.
    Sep 2005
    1740
    Re: Which CNC for cutting?
    They make a knife holder( spring loaded) for holding the vinyl blades that can be used on a CNC router. I think they are about $250 USD, dead simple to figure out and use. I made one for my CNC plasma cutter a long time ago and it worked beautifully. Your Z motor on a CNC router does the up and down movements for you, the one you have pictured looks expensive but maybe you don't mind. I think if you had a CNC router the knife setup would work, it does for vinyl anyway. Sandblasting media vinyl is what you need to ask about cutting.
    you can try co2 laser cutting machine ,working size 600*900, equip 60w laser tube, which can cut 1mm rubber
    Jun 2019
    4
    Quote Originally Posted by flora View Post
    That was my first try before going the CNC route. It cuts, no problem but my material is printed and the laser cut does a big mess letting some black burnt dust everywhere: as soon as you manipulate the cut material, you have black fingers and your clothing are dead.
    So, let's forget about laser.
    Jun 2019
    4
    Quote Originally Posted by wmgeorge View Post
    The vinyl blades are not strong enough....and need a tangential holder, hense the price. If you know a cheaper tangential holder, please, tell me ;-)
    Sep 2005
    1740
    Quote Originally Posted by JeanJean View Post
    You need a top notch CNC Router and these knifes should work, you decide.
    Donek Drag Knife | Avid CNC | CNC Router Parts
    Jun 2019
    4
    "You need a top notch CNC Router "
    What are your suggestions? is this enough BZT PF 1000-P?
    "and these knifes should work"
    These knife should cut, yes but: can't find the tangential holder used in the video demo.
    Feb 2009
    6028
    This is where a waterjet is the way to go.
    Cheapest one I know of
    https://shop.wazer.com/?gclid=Cj0KCQ...YaAt69EALw_wcB
    Sep 2005
    1740
    Sorry, your going to have to figure some of this out yourself. The Link I posted is to heavy duty knife holder, your going to need to decide.
    Sep 2019
    I have personally built a 12x8ft cutting table that uses a tangential knife (4th axis) it was ton of work to get it working correctly and reliably. I used mycnc from pv-automation as the controller. The machine I built is in the $50,000 range but it uses the same cutting head. If your cutting 1mm rubber you can do it with a 40 watt oscillating knife which is going to be the cheapest option.
  1. 6KW fiber laser cutting machines for hticker steel cutting , cheaper price
    By laserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-08-2017, 05:03 AM
  2. LAser cutting machine makes a wave in a corner at the time of cutting
    By angeldp in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-08-2017, 03:51 PM
  3. metal sheet laser cutting machine fiber cutting or mix laser cutting
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-19-2015, 09:03 AM
  4. Replies: 0
    Last Post: 05-06-2014, 02:41 AM
  5. LIMAC fiber laser cutting machine for stainless steel cutting video
    By limacchina in forum Fiber Laser Cutting Topics
    Last Post: 05-05-2013, 05:24 PM
